Condor 1/72 Mig-25PD - mojo returning slowly...............
    After, for me, a long absence from a blog, I'm going to ease back into this with a real unknown................Click image for larger version
    Condor are a manufacturer from the Ukraine - according to ' Scalemates ' the Mig-25 is their own moulds - and have been reboxed by Zvezda.
    I'll put up some sprue & detail shots tomorrow - but they don't look bad - engraved detail, the transparencies are a bit cloudy, and the cockpit detail is a bit sparse, but the canopy is so small you won't see much!
    I made the ICM 1/48 Mig-25RBT last year, probably the best engineered model I have ever made. I'm not expecting this to be as detailed, or go together as well, but I paid less than £10 delivered via an ebay auction - I've seen reviews with pictures of fuselages showing filler applied liberally with a butter knife, but I wonder if the reviewers had ever heard of dry fitting! - Anyway I will find out........................
    • 15800
    Hi Dave
    Glad you're back. This is very much an unknown quantity. Interested to see what you make of it. Hope it doesn't turn out to be a mojo sapper.
    • Gern
      • 9255
      I hope for your sake that this doesn't turn out like the Kitech Mig 25 that PJ bought! That one's enough to sap the mojo from anyone!
      Not sure if I'd pick a kit from an unknown manufacturer as a mojo builder. I think I'd prefer to go with something easy from Tamiya where I'd be less likely to meet problems which would put me off.
        A nice bright evening - so I took some sprue shots & details............Click image for larger version
ID:	1101842Click image for larger version
ID:	1101843Click image for larger version
ID:	1101844Click image for larger version
        Both Russian and Libyan versions..................Click image for larger version
ID:	1101847Click image for larger version
ID:	1101848Click image for larger version
ID:	1101849Click image for larger version
ID:	1101850Click image for larger version
ID:	1101851Click image for larger version
        Some parts will need a bit of clean up, but not too bad - a few injector pin marks, but no short shots or distortions.
        I just hope it will end up looking approximately like thisClick image for larger version
        • yak face
          • Jun 2009
          • 13870
          • Tony
          Aah Condor! ( viewers under the age of forty will have no idea what that’s referencing!,) This brings back memories Dave , I built one of these for the Cold War GB a few years back , my build log might prove useful during your build . I’m on the iPad And haven’t had it long so don’t know how to copy and link the thread title so you’ll have to use the search facility , put in ‘Foxbat’ and yak face in the members box and it should bring up the build thread and the completed thread , hope this helps , cheers tony
            Tony,
            Many thanks for your pointers just read through your blogs on the Condor Foxbat - I suspected that the wing joint was going to be a problem, that was confirmed. Mine is the PD version - what the difference is is not clear, unless it's the central external fuel tank, or the ability to carry paired Aphid missiles on the outer pylons - a few photo references will have to be consulted...........
            Ah yes, the Condor moment! Along with St Bruno....................... when was the last time you saw anyone smoking a pipe?
            • yak face
              • Jun 2009
              • 13870
              • Tony
              The PD was outwardly the same as the P ,just a different radar and slightly different engines / exhausts . The other difference is as you say the ability to carry a pair of Aphids on the outer pylons .
                Go to the page, make sure the full address bar is showing (tap it if it’s just a thin bar at the top of the screen), and then tap the URL. It will expand to show the whole URL and select it (pale blue background), while the keyboard also comes up at the bottom of the screen. At the top left of that keyboard is a “copy” icon that looks like two squares, next to the scissors icon. Tap the one with the two squares.
                Next, write your reply to the message, and to put the link into it, press the Paste button at the top left of the keyboard. It looks like a clipboard with an empty square in front of it, and is next to the two curved arrows (those are for undo and redo). If the icon is grey, you can’t paste because you haven’t copied anything that can be pasted.
                • yak face
                  • Jun 2009
                  • 13870
                  • Tony
                  Thanks jakko ill try that :thumb2:
                  • Lee Drennen
                    • 7711
                    Great to see you are back Dave great looking kit
                    • yak face
                      • Jun 2009
                      • 13870
                      • Tony
                      Done it! Cheers Jakko , I now know how to link on the iPad :thumb2::thumb2:
                        Next step: hiding the ugly URL :smiling3: Tap the “chain” icon in the button bar above the text field, paste the URL into the “URL” field and type the text you want to be clickable into the “Text” field, then of course tap the “Insert” button.
                        Alternatively, type a square bracket [ICODE][[/ICODE] followed by the text you want to be a link, then the matching square bracket [ICODE]][/ICODE] and a parentheses [ICODE]([/ICODE], then paste the URL, and type the closing parentheses [ICODE])[/ICODE]. That is, like this:
                        Code:
                        [The Scale Models Forum site](https://www.scale-models.co.uk)
                          And I thought iPads were supposed to be intuitive & easy!!!!!!!!!!
                          Dave ( Mere Windows PC user )
                            They are, but typing is easier with an actual keyboard.
                              Plastic & Cement meet..............Click image for larger version
                              A fair amount of clean up & edge preparation - but fit is reasonable, at the moment. I can see that the single piece wings to the stub on the fuselage is going to be troublesome, but I hope to use plastic card & strip to minimise the use of filler. So far, so good!
