The new build is the FAIREY FIREFLY a kit made by Aerographics,the model is a very impressive 25 inches wingspan and construction is built on two crutches for the fuselage ie botton and top sections of the fuselage which are joined together once built,this is a fairly complex model as nothing on the Firefly is in a straight line ! however it is a mosty attractive subject and I am looking forward to getting to grips with it,firstly there are several sheets of parts to cut out from the printwood a task that I will do this coming week,then I will start to build the fuselage.
There is a good chance that I will convert this straight away for micro radio,it is an ideal subject,a decision will be made on this once I get into the build and see how it goes.
As usual with Aerographics the wood is excellent quality,it looks like sheeting wood has to be provided and is not included in the kit.
Lots of printwood to cut out a start has already been made.
Cutting out has begun.
Very nice cockpit canopy and a vacuum moulding for the lower nose.
Very nice drawings,once again a good feature of Aerographics.
