A good sanding down and blending of the empenage has taken place,the navigators rear area has been cut out and black card from a chocolate box glued into place,some detailing will be added before the area is closed with the rear canopy glazing,instrument panel detail has been added and a start made on the top nose planking,the formers were relieved by sanding carefully to take this,planking is done one at a time on both sides pinning and glueing down the planks gently.
Instrument panel made from chocolate box card,see method below.
First plank goes into place resting on the keel member,the planks go all around the nose and will eventually be sanded to blend everything in.
Rear fuselage has been sanded down and navigators cockpit has a black card panel to kill the void,some detail will be added before closure with the plastic sheet canopy.
Cross pieces were removed that acted as strengtheners during the fuselage build.
Nicely blended and sanded empenage,soft balsa block around the tailwheel was a modification,much happier now as this has locked everything into place.
Simple instrument panel made with black chocolate box card and paint applied with paper drinks straw.
Lay some white paint onto a piece of card,dab a straw into the paint and gently touch the instrument panel marking the bezels,no need to be perfect just suggest the instruments,once the glazing is in place it will take the bare wood effect away from the cockpit area,it is not going to weigh anything and is done purely for effect.
Finer detail is done with a 000 brush.
