Thanks John.
ESCI 1/48 Henschel HS 129
[ATTACH]37276.vB[/ATTACH]
I masked the underside of the model this morning.Then i decided to put a coat of RLM71 Dunkelgrun on.I had some of my usual Xtracolour paint pre-thinned in a tinlet.When i loaded up my airbrush and tried to spray it the brush clogged up.I cleaned the airbrush and tried again,but with the same result.So i ran out of paint.I looked on 'Angelfire.com' which is a Humbrol paint reference table.It gives Humbrol no.30 as an equivalent of RLM71.As i have two tins of the stuff i sprayed some on the model.I have to say im not sure about this colour.Especially as i used to use it years ago as RAF Dark Green for Lancasters and the like!.My local hobby shop stocks Vallejo paints.So i might try to find a shade that is closer to RLM71.
[ATTACH]41469.IPB[/ATTACH]
Attached FilesComment
Hi dave , irrespective of whether the colour is right ,it looks great so far. Im sure steve will be along soon with some paint advice, im afraid im not the best person to offer any sort of opinion on luftwaffe stuff , any that i do i just get the xtracrylix rlm no. paint and blast it on and trust that they know their stuff!! cheers tonyComment
Dave it does look a tad too vibrant of a green tint, but hey its still a great looking build and with the other color, decals and weathering bet most would'nt be able to call it off at all.Comment
[ATTACH]37311.vB[/ATTACH][ATTACH]37312.vB[/ATTACH]
I was going to go with the Humbrol no.30 green.But after seeing the shade that Vallejo call RLM71 i wasnt happy with it.So i went up town this morning and got some Vallejo.The shop had sold out in the normal Vallejo range,so i had to buy the Vallejo model air equivalent.I found the model air code by looking it up on an iphone app suggested by Scuff this morning (thanks again scuff).As i wouldnt be able to spray the Schwarzgrun enamel paint i already had over the top of the Vallejo acrylic,I got some Vallejo Schwarzgrun as well.In the first photo the right wing is in the humbrol colour and the rest of the model is the Vallejo paint.Quite a difference in colour.Not sure how long to leave it to dry before masking off the camouflage pattern.So i will treat it like enamel and leave it a day at least.I've only used Vallejo clear varnishes before which are superb.After using the Dunkelgrun i can see what all the fuss is about.So easy to use and gives a superb finish.I was able to clean the airbrush with water as well.Definately getting some more.Time i fazed out the enamels anyway
[ATTACH]41502.IPB[/ATTACH]
[ATTACH]41503.IPB[/ATTACH]
[ATTACH]37365.vB[/ATTACH][ATTACH]37366.vB[/ATTACH][ATTACH]37367.vB[/ATTACH][ATTACH]37368.vB[/ATTACH][ATTACH]37369.vB[/ATTACH]
After leaving the Dunkelgrun for 24hours i tinight masked off the camouflage patern.I then sprayed on Vallejo Air Schwarzgrun Taking care to spray away from the tape edges rather than against then.This way i shouldnt get a ridge of paint between the two colours.I then removed all masking from the model.And im very pleased with the results.Just need to give the upper surfaces a couple of coats of Kleer before applying decals.
[ATTACH]41553.IPB[/ATTACH]
[ATTACH]41554.IPB[/ATTACH]
[ATTACH]41555.IPB[/ATTACH]
[ATTACH]41556.IPB[/ATTACH]
[ATTACH]41557.IPB[/ATTACH]
Looking very nice Dave, will look the Bizz with the decals on & a bit of wethering.
Keep up the good work & have fun.
JohnComment
