Tamiya 1/48 Douglas F4D-1 Skyray
    This caught my eye in the stash last week, and after finishing the HobbyBoss Lightning for the P-38 GB. I retrieved it for my next build. Not a very complex build, but nicely engineered in the Tamiya style.Click image for larger version
Name:	tamiya skyray (1).jpg
    The pilot has gone AWOL, but I do have a small Eduard PE set, mainly to dress up the cockpit.
    I'll put up some detail shots tomorrow - a lot of parts are off the sprues already, but nothing assembled.
    The model dates from 1998 - it has nice engraved detail - a few sprue shots..................Click image for larger version
ID:	1104331Click image for larger version
ID:	1104330Click image for larger version
ID:	1104339Click image for larger version
    The main airframe is split top & bottomClick image for larger version
ID:	1104334Click image for larger version
    Cockpit isn't bad............Click image for larger version
    Detail isn't bad - state of the art in 1998!Click image for larger version
ID:	1104333Click image for larger version
    Normal Tamiya instructions
    The Decal sheets are rather nice - I think I'm going to go with the boxtop finish.............Click image for larger version
    I have the small Eduard PE sheet
    Build options are folded wings, and extended/retracted slats - I'll see how things pan out
      After a little edge clean up - 14 parts later - the main airframe is pretty completeClick image for larger version
ID:	1104359Click image for larger version
      Assembly was just TET wicked into the joints. I'm making it with extemded wings & slats ( If you fold the wings, you have to retract the slats }. Looking to be a quick build ( so far )
        I like the look of US Navy planes of this generation — they manage to look at the same time sleek, quaint, futuristic and archaic.
          Hi Dave good clean start, nice snug fit to, great looking decal sheet.
          Hope you on the mend and feeling better.
          Pete.
            • 18930
            Good looking bird this one......so following along....
              The office has the PE instrument panel fitted - very old school, all dials..........Click image for larger version
              The ejector seat, I guess is a Douglas model, looks different to the M-B seats. Just waiting for me to fit the seat belts....Click image for larger version
              I see no mention of nose weights in the instructions - there's plenty of room in the nose, so I'll add some as insurance...........
                • 15736
                Hi Dave
                I can well understand how that box art caught your eye. Nice decals but some are rather large so hope they go on ok. I like the top/bottom body rather than the left/right one - less clean up of joins hopefully.
                  The top/bottom is engineered so that a lot of the joints are hidden - mainly behind the slat housings, but the fit is so good, that there is minimal clean up.
                  The decals may be a bit tricky, but I think that doing them more or less one at a time, allowing plenty of drying time between decals, and using a decal solution should be the best technique
                    Belt added to the seatClick image for larger version
                    Boy, it looks rough, when you magnify it!!!!!!!!!
                    I added some ball bearings before joining the front fuselage halves, sandwiching the cockpit tub. Absolutely no fit problems!Click image for larger version
                    • rtfoe
                      • 9099
                      That's quick Dave.
                        It is a Tamiya kit, though …
                        • rtfoe
                          • 9099
                          Yup forgot about that. It helps really.
                            Yes, not many parts, and the fit so good, that it really fall together. When you consider it dates from 1998, it must have been really state of the art moulding then!
                              • 22771
                              Nice work so far Dave. The wing and tail section reminds me a little of the flying sub from Voyage to the bottom of the sea.
