Tamiya 1/48 Douglas F4D-1 Skyray
    Taking it slowly and carefully should do the trick, is my experience. Looking good so far.
      All the major decals are on ( at least on the uppersurfaces )Click image for larger version
      Needed a few applications of the Mig No 2 Decal solution to get them to sit down ( those on the spine ), but all in all not too bad.
      I had more trouble putting the decals on the drop tanks, than the main airframe, they wrinkled, tore and misbehaved, but I wore them down..............Click image for larger version
      I have had one failure - the warning decal for the port inlet, I couldn't get to fit - after applications of decal solution, & much prodding, it eventually fell apart, and I had to ditch it. I'm now going to have to brush paint the red strips - oh well!
      • boatman
        • Nov 2018
        • 14498
        • christopher
        • NORFOLK UK
        #33
        HI Dave it looks great to me well done on getting that big tail decal on perfect as I know they can curl up an be a right pain :thumb2:
        chris
          All decals now applied - all behaved, apart from the drop tank piecesClick image for larger version
          I hand painted the red warning strips on the inlet edges - lust a bit of tidying up here and there, and this is approaching a finish. No weathering - all pictures I've seen of the F4D in service show it in very good condition.
          • boatman
            • Nov 2018
            • 14498
            • christopher
            • NORFOLK UK
            #35
            NICE
              • 15799
              Hi Dave
              Come together quickly - Tamiya fit helps. Paint job looks great and those decals are stunning.
              • adt70hk
                • Sep 2019
                • 10438
                #37
                Looking very nicely done indeed.
                  Nearly a baad mistake - I'd just added the drop tanks & decided to fit the canopy - applied the PVA, then suddenly realised something was missing - the ejector seat! Just in time ( not that you can see a lot of it!
                    The good hing about PVA glue is that it comes apart easily if you use it for plastic Still, better to catch it in time, like you did, of course.
                      Finished! I'm waiting for the satin varnish to dry - the light is fading fast, so I'll wait until tomorrow to take some pictures of the finished article......................
                      Now in completed aircraft section
                        • 18272
                        I found I had done that as well. Only I found out when I took the masking off the canopy the next day... Duh!
                          • 18272
                          Op's wrong button
                          Looking good that.
