Looks like a nicely engineered kit. One of the very few planes I ever built a long time ago.
Airfix 1:72 Blackburn Buccaneer S.2C
Part:
Instruction:
PE:
That etched set seems to be for another kit than this, where you can just glue the etched parts to a flat “end” of the wing. If it’s intended for this kit, then I’m not seeing how it’s supposed to fit either.Comment
I had a quick look at the PE for this and then the kit and couldn’t figure out how they could possibly work.
Part:
[ATTACH alt="A52A62D9-25ED-4681-91F6-A2AA1B85D51D.jpeg"]359381[/ATTACH]
Instruction:
[ATTACH alt="847504C1-6B49-483C-96C0-5FDA0DFA7B40.jpeg"]359379[/ATTACH]
PE:
[ATTACH alt="A1E83E7D-3C01-40A0-938B-1F7C809AA1B6.png"]359380[/ATTACH]Comment
Not to worry Richard. The instructions called for 15g, I went for 17g, although, it was a hell of a tight fit getting it all in. I might just have to leave the hook down on this one, just in case.
Well, I think I have enough sub assemblies to make something like a Buccaneer.
A problem, at last. I knew it was going too well. The rear seat appears to be too high, the question is, can I persuade the seat out without any damage ?
Yes, that came out ok. See the square chunk on the bottom, it's supposed to be there, but maybe not that long.
Right then, even with the seat out, there's still a bit of a problem. It's like I need to thin the end of the canopy down a bit. No drama, an easy fix.
Or, just slide the canopy back, that'll work. Ignore the gap at the front part of the canopy, it isn't fixed yet.
The airbrake. A nice bit of detail, so it has to be open. A closed option is provided.
Now we are staring to look like a Bucc'
That seems to be typical of these modern Airfix kits: they’re well-detailed and fit is generally good, but you get the odd thing that needs a lot of work to fix, and which you’ll probably only discover long after you wish you had.Comment
Nice build there is one of these sitting outside a local garge on the road to lossie not as tidy as your its a bit more weatheredOk so no an exact replica but closeAttached FilesWhy is common sense not so common?Comment
Given the name of the filling station I see why they’d want to put a jet fighter next to it, but it still looks very odd to see that standing by the side of the road. Mind you, typing that made me remember that some years ago, someone living just outside the next village over from where I live, had a helicopter in the front garden, and I also know a house with an FV 433 Abbot in the garden.Comment
