2x Bf 109 F-4 (1/48)
    Originally posted by Steven000
    :dizzy: I just spend ONE HOUR masking this first part with Tamiya 6mm tape ...
    I mask the whole canopy and then cut out the framing with a sharp knife. This is much easier and quicker than trying to cut masking tape to the right size for each of the different panes of glass.
    • Si Benson
      • 3572
      #17
      Hi Steven,
      lovely work on the two planes:thumb2:
      • AlanG
        • 6296
        #18
        Steven. For gluing clear parts i tend to use Micro Kristal Klear
        • colin m
          • 8770
          • Colin
          • Stafford, UK
          #19
          Great work Steven. Masking canopies, yes I feel your pain. Then again, I have masked a B36, probably something I will never do again.
          • AlanG
            • 6296
            #20
            I've got a He111 build coming up. My eyes are twitching at the thought of it.
            • colin m
              • 8770
              • Colin
              • Stafford, UK
              #21
              I built a 1:32 He111 - and the mask set I used was marvellous !
              • Steven000
                • Aug 2018
                • 2830
                • Steven
                • Belgium
                #22
                Thanks all :thumb2:
                Al: Yeah I read some good things about Micro Kristal Klear, also used for filling small windows etc, will put that on my shopping-list.
                Jakko: I tried something like that but the clear parts didn't have 'deep' lines on them so it was a pain to follow them with the knife :thinking:.
                Si: Thanks, I hope they look nice in the end :thumb2:
                Colin: I feel your pain... :dizzy:
                This evening I was able to mask the engine and interior of the open cockpit,
                then I sprayed a dark grey on the canopies (for the interior color) and ended with a grey primer (vallejo)...
                Maybe I can add some color tomorrow! I hope all that masking will turn out ok in the end :thinking:...
                Thanks and kind regards,
                Steven
                  Holding the canopy up to the light will probably let you see where to cut. Of course, it’s a bit more difficult holding the part above your head while cutting the masking tape
                  • flyjoe180
                    • Jan 2012
                    • 12433
                    • Joe
                    • Earth
                    #24
                    Your Messerschmitts are looking really good Steven.
                    • stillp
                      • 8097
                      • Pete
                      • Rugby
                      #25
                      Originally posted by Jakko
                      Holding the canopy up to the light will probably let you see where to cut. Of course, it’s a bit more difficult holding the part above your head while cutting the masking tape :smiling3:
                      Another tip I've heard is to use the torch on a smartphone laid on the bench with the canopy over it.
                      • Steven000
                        • Aug 2018
                        • 2830
                        • Steven
                        • Belgium
                        #26
                        Thanks Jakko, Joe & Peter,
                        A small update :
                        The spinner had this sad looking nose canon, which has an oval shape and no barrel-hole
                        So I searched my plastic-scrap box and found these tubes with a matching diameter (left) ...
                        Next I drilled a hole in the spinner (right) ...
                        Then the tube was cut and fitted with superglue, both spinners were modified.
                        I melted a sprue again and made a brake-line for each undercarriage strut.
                        In the first one I tried to simulate the curly shape at the bottom,
                        but this was hard to get right and as the wheel will cover it anyway I made the other ones simply straight...
                        The day before I cleaned the nozzle of my airbrush (H&S, Hansa 381), all was nice and shinny again but then all hell broke loose and I got bubbles in my cup when spraying...
                        As far as I understand this is caused by an air-leak inside the paint feed, so the only thing it could be was this very tiny rubber seal.
                        I never replaced this seal so it seems it has wear out...
                        I'm quite stubborn so I actually tried to fix it by making a new seal from thick paper, after many attempts I made a sausage from a piece of Teflon tape which in the end seemed to work for about 90%, some very fine bubbles kept coming but it was possible to airbrush again until a new seal arrives...
                        I also took these figures from another ICM kit, Revell has reproduced them too.
                        I was able to spray on some primer on these parts, the figure on the right seems to be smaller than 1/48 :thinking:
                        And a first coat of sand yellow was sprayed on top of the Trop-version...
                        Next week I hope to add the blue and white areas.
                        I just ordered a new seal for my airbrush so hopefully this will be an easy fix (fingers crossed) ...
                        Kind regards,
                        Steven
                          How tall is he? Hold a ruler next to him should show quickly enough whether he’s undersize or not.
                          • Steven000
                            • Aug 2018
                            • 2830
                            • Steven
                            • Belgium
                            #28
                            Yes it's how I noticed it, I always take 1m80 divided by the scale (48) and he was about 3-4mm smaller, don't remeber the exact height, already on the train for work ; D
                            • Mini Me
                              • Jun 2018
                              • 10711
                              #29
                              Do a forced perspective and use him in the background should work well in a Dio.
                              cheers, Rick H.
                                • 15743
                                Hi Steven
                                Just had a catch up from the beginning. Really sorted, neat work. The engine is much improved with your stretched sprue piping. Love what you have done with the sand filter.. Masking is a chore but has to be done. Glad you got the AB working.
