2x Bf 109 F-4 (1/48)
    Excellent modelling Steven :smiling3:.
    • Steven000
      • Aug 2018
      • 2830
      • Steven
      • Belgium
      #77
      Thanks guys! :thumb2:
      This afternoon I started working on the MDF-base, the trop-plane-scheme I did was from 'Martuba' in Libya (North Africa, 1942).
      To get an idea of the landscape and colors I searched google for a few minutes and used these images from the region (Martuba).
      Some nice earth-tones, small rocks and bushes...
      I have some sand and stones that I collected and filtered a while ago, started gluing the largest rocks...
      Then I added wood-glue, smaller rocks and a layer of fine white-sand.
      In the end I thinned some more wood-glue and dropped it on the surface with a pipette. The edge was masked.
      I did an attempt to make the wheels look like the're in the sand...
      After the hairdryer I sprayed some coats of black primer (vallejo)
      Then I sprayed the earth tones.
      This took me a long time as I tried to get the color right, but when I changed to a different light-source I had the make adjustments over and over again. I wasn't able to capture that 'orange' tone very well.
      Then I masked the outer-edge of the base.
      The edge was sprayed with burned umber (vallejo), here you can see the end result of the base ...
      The canopy-masking was removed and I placed the vehicles on the base temporary. Some small vegetation was added.
      Although it's a small project it sure takes me a lot of time to get things done, but I learned a lot with this one so I'm glad I got it this far.
      Next I still need to add the antenna, figures and a bit of small weathering, I also noticed I forgot to install the armor plate in the cockpit :smiling6: ...
      So that's all for now, I'm of to bed! :sleeping:
      Kind regards,
      Steven
      • Wouter
        • 742
        #78
        You can go to bed now, lucky chap lol.
        Nice base btw, really adds to the bf and kübel. Looking forward to see the details added
        • Si Benson
          • 3572
          #79
          Hi Steven,
          Really impressed with all the work you’ve been putting in, everything looks very clean and tidy:thumb2:
