I have been making solid progress. First detailing the cockpit. After the pe I did a semi matt varnish then I used Micro Kristal Klear for the glass screens and dials.
Washes and dry brushing done.
Masked the main wheel wells
Fitted the nose weight and screwed in the cockpit.
Then I screwed the top fuselage on. Perfect fit. When firmly screwed on I ran around with thin cement to seal the joins. I had to hold the pieces together in a few places, as you would expect .
Bottom of wings into place
Cockpit masked
Then I sprayed primer to check joins.
As it happens the joins are perfect needing a very light sanding in some small areas. I have never put together the two major fuselage halves before without having seams to treat. The engineering and fit is amazing.
Cockpit masked
