Airfix 1/72nd Bristol Blenheim Mk IV
  • dave
    • Nov 2012
    • 1829
    • Brussels
    This will be my next build, hopefully quicker than my Wurger. I will be building the RAF version and using the Eduard PE interior set for the cockpit as there is a lot of glazing.
ID:	1110076Click image for larger version
ID:	1110077Click image for larger version
ID:	1110078Click image for larger version
  • flyjoe180
    • Jan 2012
    • 12433
    • Joe
    • Earth
    Watching with interest Dave, I have the other boxing of this mould. Apparently the cowls are an area to watch as they build up from multiple parts. Also some issues reported about gaps between the glazing and airframe. Nothing you can't handle I'm sure. Look forward to seeing the progress reports.
    • dave
      • Nov 2012
      • 1829
      • Brussels
      The glazing cannot be any worse than the old airfix Blenheim I built as a kid.
      • dave
        • Nov 2012
        • 1829
        • Brussels
        Made a start today, but odd in that you do not start with the cockpit, but with the fuselage and wings. The cockpit then added to the front. So the main parts have been primed with Vallejo Surface Primer, and a coat of Humbrol Clear on the Glazing before I start masking.
        The intention is to build with turret retracted and wheels down as Airfix only supply a pilot with the kit and not the rest of the crew.
ID:	1110558Click image for larger version
        • dave
          • Nov 2012
          • 1829
          • Brussels
          Forgot I was out of the green/grey for the interior, so started work on the PE in the cockpit while I wait for a delivery. Resting on my home made glue spreader.
          • dave
            • Nov 2012
            • 1829
            • Brussels
            Started work on masking the canopy, I use bare metal foil over the part, then buff into all the edges with a blunt cocktail stick. Finally cut along the edges with a fine scalpel blade and peel off the frame.
ID:	1111441Click image for larger version
            • JR
              • May 2015
              • 18273
              As a none wingy person I shall sit at the back and enjoy. Nice method with the foil Dave, is it fixed in any way or does it just stick as you press it down ?
              • dave
                • Nov 2012
                • 1829
                • Brussels
                Bare metal foil is the trade name and it comes in various finishes and is self adhesive, it is intended for doing things like Chrome bumpers on cars.
                • JR
                  • May 2015
                  • 18273
                  Thanks Dave, you learn something new every time on here . :thumb2:
                  • saguy
                    • Feb 2011
                    • 570
                    as one who battles with masking of canopies i'm sure to give this method a go ..... great idea!
                    • stillp
                      • 8097
                      • Pete
                      • Rugby
                      I keep meaning to try that with some of the aluminium foil tape used for insulation boards. Dirt cheap from Screwfix.
                      • colin m
                        • 8770
                        • Colin
                        • Stafford, UK
                        It's a nice kit Dave. I built another new tool version. There was some sort of fit issue with the cockpit, if I remember, it just involved a bit of sanding here and there and all was good, nothing major.
                        • yak face
                          • Jun 2009
                          • 13853
                          • Tony
                          Careful pete that stuff sticks like you know what to a blanket , it does have its uses though , thin strips for chrome oleos and any small shiny metal panels ( see my p38m build in the next few days !) but if you stuck it on a canopy it takes a lot of getting off and usually leaves glue all over it .
                          • stillp
                            • 8097
                            • Pete
                            • Rugby
                            Thanks for the warning Tony, I'll stick to (:smiling5 Tamiya tape.
                            • dave
                              • Nov 2012
                              • 1829
                              • Brussels
                              I have to say personally I have no trouble with the Bare Metal Foil it comes off with a cocktail stick and no glue left, that may be because I use Humbrol Clear Varnish on the canopy before masking, or I have a duff sheet of foil.
                              Back on the real modeling after Notrs Dame, cockpit now being closed up, I was pleased with how well it fits together, although you need to watch out for the locating tabs on the clear parts and not remove them.
