Sorry Andy. Some how i've missed this build. Doing a cracking job on it though.
Revell 1/48 Beaufighter
Cheers Andrew.
The low bench and lack of a chair wasn't so good though. Stooping slightly aggravated my bad back (lumber region problems brought on by a bad car accident many years ago). I found myself sitting on the floor for tricky parts, working on my lap. I found that surprisingly comfortable and may even try and incorporate an open floor area when I finally get around to changing the layout.Comment
After some minor filling and sanding I started masking this up for primer & paint.
[ATTACH]369070[/ATTACH]
It all got a thin coat of Mr Surfacer 1000
[ATTACH]369071[/ATTACH]
Then I had a go at pre-shading the panel lines :smiling5:
[ATTACH]369072[/ATTACH]
As you can see, I can't paint a straight line to save my life! so decided to go heavier with the main colour than I'd planned. That has hidden the worst of it but left a little peeking through
[ATTACH]369073[/ATTACH]Comment
Cracking job Andy. Great looking build!!
How did you manage with rescribing the panel lines? One thing i cannot get to grips withComment
Thanks chaps.
Bob, a bit hit & miss if I'm honest. Some have come out pretty well, some are a bit deep, and a few aren't exactly straight!
I've got a cheap scriber which does quite well if I take it steady but can easily cut too deep. I did a few others with the blade from my new JLC razor saw and that does a really nice job, but I found it harder to keep it in a straight line, even when following a taped edge. A bit more practice and I should be ok I think.Comment
Thanks Jim. First time I've tried this method and it's trickier than it looks to follow the straight lines perfectly. Fairly happy with the outcome though.Comment
Thanks chaps.
Thanks Lee, and knowing my luck Jakko I'd stray off line with that as well! :smiling5:
To be honest I think my hands are a bit wobbly due to a significant hospital appointment that's coming up in a few days and stressing me out. Since stress can aggravate my condition it's a vicious circle :rolling:
Anyway, onto the beauty of lacquer paints - after about an hour I started masking up the lower half ready for the upper colour.
[ATTACH=CONFIG]n[/ATTACH]
John didn't have any Ocean Grey in stock unfortunately so it got Dark Sea Grey, which is very similar. I left more of the pre-shading visible here, but hopefully not too much, figuring the upper surfaces would be more prone to bleaching anyway.
And after removing the masking. The engine cowlings cover the mess at the front, and there are only a couple of minor boo boos to touch up where I wasn't perfectly accurate with the tape, so on the whole it's gone well.
[ATTACH=CONFIG]n[/ATTACH]Comment
