Pre-shade panel lines not straight? Don't worry about it. Real panel line shading doesn't conform to straightness all the time. Depends on where the dirt builds up and is rarely even (like what modellers paint).
Revell 1/48 Beaufighter
Thanks chaps.
I still haven't decided whether to have a go at the invasion stripes. Done well I think they look great, but I need to pluck up the courage first!Comment
I didn’t find them difficult to do at all, on a few 1:72 scale planes anyway. Then again, I began by painting the stripes (white first, then mask and paint the black) before doing the rest of the plane — adding them after the rest is painted may be a little more difficult, I suppose. OTOH, I’m confident this is easily within your skill, certainly looking at the masking you did on this model already.Comment
Thanks all.
Jack - it's my first time so I'm pleased with the result. I think next time I'll try a bit of mottling/marbling as well to vary the finish even more. I'm not a big fan when it's overly done but a bit of subtle variation might look well.
Jakko - I figured if I did the main painting first I'd always have the stripes as a cover up if it went wrong lol. Plus I suppose it's more accurate to paint them afterwards, not that you'd ever be able to tell the difference though. I know in real life these might be slapped on shoddily since there were thousands of aircraft to do in just a couple of days, so if I do make the odd mistake I guess I can blag it off as "realism" :smiling5:Comment
Thanks Tony.
Decided to bite the bullet and tackle those stripe today. After a bit more research it seems they would have been 24" wide for a twin engined fighter like this, which scaled down pretty nicely to two strips of the 6mm 3M fine line tape I have.
At first I wasn't sure whether to paint it or roast it!
[ATTACH]369189[/ATTACH]
I then built up a few layers of well thinned down white, trying to avoid the single-block-of-stark-colour look
[ATTACH]369190[/ATTACH]
Then some more masking for the black. If my wife had her way she'd get me to leave it like this, since she's a life long Sheffield Wednesday fan! :smiling5:
[ATTACH]369191[/ATTACH]
Then a few coats of "almost black", again applied carefully to give some variation, and it was time to unwrap. There are a couple of places where the paint has tracked under the tape at a panel line, but nothing a little touch up and wash won't sort.
[ATTACH]369192[/ATTACH]
[ATTACH]369193[/ATTACH]
[ATTACH]369194[/ATTACH]
In between all the masking and drying times I started on some of the smaller pieces like the yellow for the propeller tips. The spiky exhausts were given a coat of steel as a base for a bit of light rust work.
I had a hard time finding colour references for the torpedo so went with something similar to the instructions, a custom blue/grey at the front, with the main part being a mixture of steel and silver, which turned up just in the nick of time from John at the shop. I'll hand paint the wooden "fin" at the back later.
[ATTACH]369195[/ATTACH]Comment
Thanks chaps. I can't remember ever doing so much intricate masking but I think it's paid off.
And thanks John, fingers crossed.Comment
Not that you need to, looking at the photos.
