Nothing much to report, just going through the process of adding some of the fragile parts and knocking them off again lol, but I'm looking for colour suggestions for a panel line wash on the upper surfaces.
I only have back & brown in actual MIG washes so used the brown underneath. Doesn't look as bad as it sounds but I don't know if it would suit the grey/black/white up top. My cheap oils tend to go a bit grainy when mixed as a wash but have a few oilbrushers and plenty of acrylics so could manage to cobble together whatever is suggested somehow.
I tend to go for simply a darker version of the base colour I’m applying the wash over, or a generic grey stain (that is, transparent grey much like Tamiya smoke but home-brew and a bit lighter in shade) that works on a lot of colours.
I’m by no means an expert aircraft modeller, though You could always try a couple of panel lines and paint over them again if it doesn’t look right.
Hi Andy, I've been busy hosting relatives the past month through New Year so did a little catching up on your build. Very good I have to say including the pre-shading and invasion stripes. :thumb2:
I use watercolor for my panel lines and can mix up any shade and as translucent as I want. Just needs a dash of dishwashing detergent to break up the surface tension so it sticks. Easy clean up with a damp cloth or cutip and just needs a coat of varnish to seal it. Here's examples of what I normally do...the first picture looks scary...
Thanks Richard. I'd consider you a master of pre-shading so for you to give me a thumbs up is much appreciated.
I'm following your Night Fighter build and have been intrigued by the watercolour washes. If I had some I'd be giving them a go but I'll store that up as something to try in the future. I haven't had much luck with enamel or oil washes, and it's always a stage I dread, so anything that makes that part of the process easier and less stressful is a bonus!
So, after a few days of applying washes, airbrush shading with "smoke", and several hours of oil dot work it looks...
virtually no different! :smiling5:
Before:
[ATTACH]369853[/ATTACH]
After:
[ATTACH]369854[/ATTACH]
Clearly time well spent lol.
Time to stop faffing around with the stuff I don't understand and just finish building it I think, then add it to my growing collection of 90% finished kits :upside:
It has turned a bit browner though or could be the tone of the image. :smiling2: Dirtying is not everyones cup of tea. You paint cars for a living that need to be spotlessly clean and shiny so you need to relax and let your hair down...I mean guard down and just go messy. Start by working on a spot, don't worry if one area looks more weathered...there are no mirror images of dirt like both wings can look different.
Anyway Andy, for now it just needs panel lines. Do you have any kids watercolor around the house?...try that with a little detergent. If you don't like it just wash it off.
Unfortunately not Richard. I had a look when I first saw you mention them.
You wouldn't know it but the panel lines have been done. Twice. Once with a MIG PLW that didn't really work, then again with thinned oilbrushers that wasn't much better. They are exceedingly shallow though so even with gentle wiping from a dry cloth after 24 hours to cure the paint just pulls out!
I guess next time I'll have to scribe them a bit deeper.
As seen on the underside - where the lines are deeper around the engines and undercarriage doors the PLW has stayed put. Elsewhere it's pretty much disappeared.
