A couple of pictures.
more decals applied to the Phoenix but with a lot more still to do
the attrition rate is about 75% with these dreadful Trumpeter decals. I did not apply them to the underside where they won’t be seen. Also there are enough for six Pheonix and I am only building four so it is working out. Note that the sizing is a little off. I decided that they don’t look too bad with the naked eye so I am not adding to the attrition rate by trying to cut them down.
Below the aircraft after the touch up awaiting her decals.
I decided not to so a really dirty mottled appearance as I have seen on many F14 builds. I decided to keep the weathering fairly moderate, hence the more subtle colour modulation. I like to be a bit different and heavily mottled look is a bit too ‘fashionable’ with F14s.
The MRP paint is glossy enough so I am not gloss coat first before decals. I will apply a semi-gloss coat to seal decals a prep for washes.
