Neat interior and paint work Andy :thumb2:.
Tamiya 1/48 P-38 Lightning
And thanks Fernando, so far so good.Comment
You’ve got a punch-and-die set, if I’m not mistaken? You can use that to make some circles from masking tape, if it has punches about the right size.Comment
I've not had any luck with punching circles out of masking tape. It seems to work best if I stick the tape to some thin plastic sheet (cut from an ice cream tub or similar) then peel the tape off. The tape on its own just want to stick to the die insted of cutting cleanly.
PeteComment
Good idea Jakko. I've just checked and the largest punch would just have been big enough for the smallest lights. I'll store that one up for next time thanks, along with Pete's method of sticking it to some thin plastic.Comment
Things looked a little hairy at first but I'm happy to say the watercolour wash seemed to work great. Nothing fell off either which is a problem I've had ever since I started using enamel washes.
[ATTACH]372663[/ATTACH]
After about an hour the excess wiped off really easily. Dry kitchen roll was used mostly, with a few stubborn parts needing a tiny bit of moisture, but the condensation from breathing on it was enough.
[ATTACH]372664[/ATTACH]
I then added the turbochargers, started layering the staining around them, and gave it a flat coat of Winsor & Newton Galeria.
[ATTACH]372665[/ATTACH]
Exhaust staining looks a bit pink in the pictures but I'm hoping it will come good with the planned oil work.
[ATTACH]372666[/ATTACH]Comment
Andy,
This is really good work, but I must say I'm getting fed up now everything you try for the first time you master lol. Keep it up mate.Comment
Those panel lines look very wellComment
Thanks everyone, I really appreciate the comments.
Paul - I really wish that were true mate. You haven't seen the 700 models I've ruined in practice :smiling5: I like to think I'm getting the hang of some things fairly quickly though, but that hairspray chipping is still a black art!Comment
