Bf 109 G-2 (Trumpeter 1/24)
  • Steven000
    • Aug 2018
    • 2830
    • Steven
    • Belgium
    Hi guys,
    This Bf109 in 1/24 scale will be my next project!
    It's been waiting for me in the stash for a while now but I wanted to gain some experience with airplanes first before messing with it.
    I plan to[COLOR=rgb(41, 105, 176)] [/COLOR][COLOR=rgb(41, 105, 176)]hang it[/COLOR] up to the ceiling (because of it size), so I will build it with the [COLOR=rgb(41, 105, 176)]landing gear up[/COLOR] and a resin [COLOR=rgb(41, 105, 176)]pilot[/COLOR][COLOR=rgb(41, 105, 176)] [/COLOR]searching for a kill his seat...
    It's quite a big box, it had a bit of transport-damage but all parts were fine.
    I made some Sprue-shots :
    A drop-tank is also included...
    Engine parts...
    Extra clear parts for the fuselage as an option...
    A small box includes the rubber, metal and clear parts.
    I read bad things about rubber-tires, I will have the gear retracted so I don't think I'll have much issues with it...
    Decals.
    I like the drawings in the instructions, all very clean and clear.
    I already started working on the cockpit and pilot, but those pictures will follow later (lack of time)
    Thanks for reading and kind regards,
    Steven
    A fine looking kit Steven. Enjoy.
      Has it got a full interior, including bits that are normally out of sight? (Like the old Matchbox 1:32 scale aircraft that I have fond memories of ) Else I can’t really see the point of the clear fuselage parts.
      • Jack L
        • Jul 2018
        • 1273
        • Cheltenham
        Originally posted by Jakko
        Has it got a full interior, including bits that are normally out of sight? (Like the old Matchbox 1:32 scale aircraft that I have fond memories of :smiling3 Else I can’t really see the point of the clear fuselage parts.
        Instructions show the engine, so guess that answers your question @Jakko
          It also has separate engine panels, so you can display the engine without having a clear fuselage if you want. I was thinking of the stuff that’s elsewhere in the fuselage, like the guns and their ammo bins between the engine and the cockpit, and whatever is located in the (probably mostly empty) rear fuselage.
            • 22771
            Just pulled up my chair Steven
              • 15735
              Hi Steven
              Watching with interest.
              • Steven000
                • Aug 2018
                • 2830
                • Steven
                • Belgium
                Well it seems only the engine would be visible through the clear-fuselage-parts, there's no radio gear or something like that in the kit...
                But because those clear-fuselage-parts are using the same mold as the grey-plastic-fuselage it will be very hard to make it look nice,
                as this kit has a lots of injector-marks...
                The instrument panel is a clear part too, a plastic-sheet with gauges has to be glued behind it, first time I see this.
                I painted the base colors on the instrument panel...
                I bought this resin 1/24 pilot, he has basic detail but will be good enough for hanging up to the ceiling : ).
                After cleaning up I've cut his arm and thumb, re-positioned his arm so he can hold the stick...
                Then re-attached his thumb (space left for the stick) and used some filler.
                Here he got a bit of black and grey primer...
                This is his cockpit, primer and grey base color are sprayed on...
                All parts fitted very well.
                Base color
                Base color
                And a few more assembled pieces ...
                I will do a 'spiral' spinner :thumb2:
                Thanks for reading ; )
                Kind regards
                Steven
                • adt70hk
                  • Sep 2019
                  • 10422
                  Looking very good so far Steven. At 1/24 I imagine it's not a small kit and as for hanging it from the ceiling, that brings back childhood memories!!! :smiling3:
                  Keep up the good work.
                    So it’s really just a novelty rather than actually useful or interesting, especially given the ejector pin marks.
                    [ATTACH=CONFIG]n1113834[/ATTACH]
                    Another strange one. I would have expected a clear instrument panel with the glass faces of the dials moulded shut, instead of as holes in the part. The one you’re showing there doesn’t seem to have any benefit over an opaque part. If they had moulded the dial glass as part of the panel, you could mask the dials and paint the rest to have realistic-looking instruments.
                    • Steven000
                      • Aug 2018
                      • 2830
                      • Steven
                      • Belgium
                      I had the same thoughts about that Jakko, the clear panel is also rather tick (tickness of the holes), so there's no visual benefit at all.
                      • Steven000
                        • Aug 2018
                        • 2830
                        • Steven
                        • Belgium
                        Hi guys,
                        Just a small update :
                        I painted the pilot, he's a bit rough sculpted so it was hard to paint the details but he's good enough to hang up. :smiling6:
                        I took a few pictures of the face-painting-stage, I started with the eyes and went from dark to light...
                        Then I painted his clothes, I couldn't find a good reference picture of a similar outfit/gear, so I attempted to make it credible enough.
                        That's all for now,
                        Thanks for reading and kind regards :thumb2:
                        Steven
                        • colin m
                          • 8763
                          • Colin
                          • Stafford, UK
                          Very nice. Except that useless clear fuselage - why ? Anyway, pilot chaps face, is it as simple as that, darker shades of skin first, progressively getting lighter ? That seems to be a very effective method.
                          • scottie3158
                            • 14216
                            • Holbeach
                            Steven,
                            Cracking work so far.
                            • Steven000
                              • Aug 2018
                              • 2830
                              • Steven
                              • Belgium
                              Yes it's a strange thing that clear fuselage, I think it was ment as a bonus for those who like to scratch build missing parts like a radio etc... But I would like to use it (painted) in the future with the engine to make a 'in the repairshop' dio, don't know yet...
                              Yes I always try to paint a face like that, some also like to go from light to dark...
                              Steven
