Interior assembled & basecoated, I'll do a little detail painting, before closing the fuselage up
I have to assemble the fuselage next, as a good joint for the stub wings is going to be a bit of a struggle, I fear!
Looking at the decal sheet, I think it may be aged past using. Luckily, I remembered I had a AM decal sheet Xtradecal X72-108 815 NAS - I bought it for the Swordfish and Gannet markings - now I can use the Fulmar scheme
How many times have you used a complete AM decal sheet? - this has the Fulmar, Avenger, Swordfish, Albacore, Gannet, Wessex & Lynx
Fuselage joined & stub wing added - not a brilliant fit - I needed a bit of filler & elbow grease to get things smooth
I have PE bits to fit in the wheelwells before I can add the inner wing uppers
This is turning out to be a real battle, the flap & outer wing sections have has their PE fitted - not without a lot of filing, and cursing. Despite me cutting the wings as accurately as I could, I still needed a lot of fettling to get any sort of fit!
It was also one of those days that the CA didn't want to stick......................
The major problem is the stub wings. I added the PE wheel well walls - bad move! It would be better to scratch some plastic parts instead. The PE walls are too large - the instructions say that some plastic will need to be removed to get a good fit. A minor understatement! I have had several attempts to get the wings to fit over the PE, but no go. I'm thinking that I'll have to remove the PE, and ditch the wheel well detail altogether. You will only be able to see this if you pick the model up, so I think I can live with that
This was meant to be a nice simple build, whilst I was painting my Wellington bust! - It's beginning to put me off the idea of the Fairey Gannet with it's wings folded!
YOURE doin great dave an yes I know that sometimes things don't fit but from what I see its lookin great what you have built an PLEASE PLEASE when you have built this plane PLEASE DO THE GANNET WITH ITS WINGS FOLDED as to me that's what modelin is all about takin up the challenge an havein a go as its some thing so different as ive never seen a gannet model built with its wings all folded into 3 sections ive seen the real plane taxi past me with its wing all still folded at an airshow at RAF COLTISHALL if I remember rightly back in the late 60 's an if I thought this about my ship builds as they are all scrath builds they would never have happened SO PLEASE HAVE A GO DAVE as we can all see you are a good moddeler when you put your mind to it an for me it would be something to look forward too
chris
I'm sure I will get round to the Gannet(s) - I have both the Revell boxings the T.5 and the AS. 1/4. These are pretty new tooling, a totally different generation to the old Frog antiques. I think I'll do the trainer with folded wings, and bomb bay closed, and the AS version with bomb bay open - I'll have to look out some some suitable weapons, as Revell don't supply anything for the finely detailed bay . All this WILL come to pass, but later in the year.............
