1/72 Revell Polikarpov 1-16
  • rtfoe
    • 9081
    #16
    Simon...John just loves pain :tears-of-joy::smiling6:
    • Lee Drennen
      • 7711
      #17
      John. You know I’m in front and center with this vintage build. You know I have a soft spot for these old kit no matter there short comings. Tea please preferred Yorkshire Mr Race
      • rtfoe
        • 9081
        #18
        Oh dear it's water and crackers for us now...or non at all and from a safe distance or a well placed blackboard duster will surely hit me :smiling6:
        • Mini Me
          • Jun 2018
          • 10711
          #19
          Polikarpov want a cracker...Awk! Right JR. Don't call Matron yet I'm saving my best material for later. Make mine a Tetley's, is there cream cheese for the crackers? Cheers, Rick H.
          • JR
            • May 2015
            • 18273
            #20
            Thanks
            Originally posted by rtfoe
            Sorry to hear about your mate John.
            Thanks Richard, he's out of hospital, has had his med's increased. :thumb2:
            Originally posted by SimonT
            You certainly have a knack of picking them John :smiling3:
            At least you would be able to see it more easily in large scale so less chance of missing things. New kit as well so should actually fit together
            Ha, its only a fill in while things dry, don't want to become a wingy , heaven forbid !!
            :smiling::smiling::smiling:.
            :flushed::nerd: .
            Lee pm your address, I'll send you some. !
            No your quite safe Richard, i'd probably miss ! ......................and hit Lee. !!!!!.
            Matron is busy in China at the moment, but can reroute to see you if you carry on like this. :thinking::thinking::thinking::smiling3: .
            Well having put the new needles and tips in I thought all would be well. Sprayed a coat both to the top and base, now all washed off , utter rubbish, large spots of paint. Just nor flowing atall well .Ive checked with neat, to thinned , still the same ?
            Seems to have very low pressure, regardless what the gauge says. I even removed the bottom drain plug, no great woosh of air either.
            When I spray the paint seems very under pressure, even when I turned up the setting to 40, no difference !
            I've used both of the ab's and both seem to be the same just lacking in air. Yet when I depress the value in the connector to the ab there is air there.All very strange,so .4 and .2 in each ab are effected.
            Has any one any idea.
            Going to post this as well in ab section.
              • 15687
              Hi John
              Fingers crossed for your mate.
              You ain't having much luck at the moment. The kit is a challenge for sure and now the compressor :sad:
              • BigGreg
                • 2182
                #22
                keep up... looking forward for next installment... MMOOORRREE
                • JR
                  • May 2015
                  • 18273
                  #23
                  Originally posted by Jim R
                  Hi John
                  Thanks Jim, not going to mess around trying to get that bolt out, hopefully my mate will remove it with out a problem. In the meantime I'll source a new one.
                  As to luck and the challenge I agree, but just press on regardless.:upside:
                  Hi Greg, thanks for looking in.
                  John.
                  • JR
                    • May 2015
                    • 18273
                    #24
                    Right the tension is building with the imminent arrival of the new compressor , so painting can continue.
                    Now what's with this black art ," panel line" if any one can advise what I need to do I'd be grateful. I know can search U Tube but would rather ask here before confusing my self .
                    Thanks .
                    • stillp
                      • 8093
                      • Pete
                      • Rugby
                      #25
                      Does an I-16 have any actual panel lines John?
                      • JR
                        • May 2015
                        • 18273
                        #26
                        Pete I have no idea ! Think I will investigate further as to what a panel line is :smiling:.
                        • JR
                          • May 2015
                          • 18273
                          #27
                          Pete, having search the web I'm none the wiser, looking at the plane it appears to have these lines on the wing.Click image for larger version
                          Is this what I mean ?
                          • scottie3158
                            • 14201
                            • Holbeach
                            #28
                            John,
                            Great work mate.
                              looking at the plane it appears to have these lines on the wing.[ATTACH=CONFIG]n1114473[/ATTACH]
                              Those raised lines represent the fabric covering of the wing being stretched over the ribs. The leading edges of the wings were aluminium, as were the inner sections where your model shows flat plates.
                                • 18901
                                Hi John
                                Panel lines are basically a pin wash for aircraft......personally I use a home brew oil wash using an appropriate oil colour diluted with sansodor thinner....there are many commercial solutions out there, but I would avoid the lifecolour panel line stuff, I couldn’t get it to work at all....
                                Flory washes are mentioned a lot, and next time I make an aircraft I wI’ll try them.
                                One thing to remember is that the wash excess is dragged off in the direction of airflow, unlike tanks where you follow the direction of gravity.
