I really like the look of the He111, those huge wings and smooth lines make everything look quite elegant. It will be nice to see this one built.
1/48 Revell He111 H22 & V-1 Rocket
Made a start on it today. Progress is slow as the instructions aren't the best and also there is a bit of flash to clean up. But it is an older kit so that's to be expected.
Opened out the seatbelt access in the back of the seat in readiness for the PE belts. Also in doing that i've had to 'remove' (badly) the moulded on belts. But the PE ones should hide the mess i've made lol.
Built up the V1 (not cleaned it up yet though). Wow it's big. I've seen one in the flesh and forgot just how big they are. I've put it next to the body of the He111 for a representation.
HI AL lookin forward to this build as I voted for this as I think it will be someththin different are you goin to have it in the flyin postion or on the ground ? an lookin at the kits fusealarge I cant really see how the bug was fitted to the hink ?
chrisComment
chrisComment
HI Tony I know the hink has got a lot of glass in the front but when I was a lot younger I built one an admitly I dint paint the inside of the glass but had a go at hand paintin on the outside it turned out reasonable not brilliant but at least it got done with a very tiny brush an I was pleased with it to me that's all that matters an I really enjoyed doin it
chrisComment
Actually the first 'cruise missile' was the BV 246 'Hagelkorn' (used by he Do215 and Fw190). It was radio controlled where as the V1 was a general direction (gimble controlled) missile. Also the V1 being called a rocket (as per the box title) is misleading. It did not use rocket propulsion but actually used pulse jet technology.Comment
