1/48 Revell He111 H22 & V-1 Rocket
    • 15737
    Hi Alan
    Great progress. You're making a fine job of this unpromising kit. Canopy masking looks neat and time consuming.
    • AlanG
      • 6296
      #107
      Did the 'squiggles' on the V-1. Not totally happy with them but. When you dry fit it to the aircraft you see hardly anything of it. So i'll accept that
ID:	1162549Click image for larger version
ID:	1162550Click image for larger version
      • adt70hk
        • Sep 2019
        • 10426
        #108
        Looks good Alan.
        A really stupid question if you don't mind......
        Was the camo purely to try and hide it whilst on the ground, or was it intended to offer some camo effect when it flight, so that if looked down at from above it might make it less visible.
        Keep up the good work.
        • AlanG
          • 6296
          #109
          If i'm honest Andrew i have no idea. But i've always liked 'squiggle' schemes
          • Mini Me
            • Jun 2018
            • 10711
            #110
            That's a right fancy bit of A/B work there Alan.....I'd be more than happy if I could achieve that effect in 1-87 scale. Looking forward to seeing how it works out on the 111. :thumb2: Rick H.
            • AlanG
              • 6296
              #111
              Actually it doesn't look quite as bad in natural daylight. Think it might be the camera and the room lights that made it look quite grainy last night.
ID:	1162562Click image for larger version
ID:	1162563Click image for larger version
                • 18931
                Both of them look fine to me Alan.
                  • 15737
                  Hi Alan
                  Successful squiggles.
                    Looks good to me. Don’t forget that German aircraft in the real world were generally not as neatly painted as models of them are (Probably especially cruise missiles like this, given the conditions under which they were manufactured plus the fact they were one-use flying machines anyway.)
                    • AlanG
                      • 6296
                      #115
                      Cheers guys. Best i crack on with the aircraft now. Need to get it finished
                      • AlanG
                        • 6296
                        #116
                        Glass house fitted. Had to do a lot of sanding (surprise surprise) to get it to fit. Also just had to dry fit the V-1 again now it's painted
ID:	1162626Click image for larger version
ID:	1162627Click image for larger version
                        • Mark1
                          • Apr 2021
                          • 4156
                          #117
                          Taking shape quite nicely by the looks of it :thumb2:
                          • Mini Me
                            • Jun 2018
                            • 10711
                            #118
                            Sweet! :thumb2: Rick H.
                            • adt70hk
                              • Sep 2019
                              • 10426
                              #119
                              Coming on nicely Alan keep up the great to work, sky-high rather you than me on all that masking.....!!
                              ATB.
                              • flyjoe180
                                • Jan 2012
                                • 12433
                                • Joe
                                • Earth
                                #120
                                Looking good Alan. Regarding the camouflage on the missile, I'd say it was for storage purposes on the ground rather than in the air. But I could be wrong, just a guess.
