P-40 Tomahawk IIb (1/48 Academy)
  • Steven000
    • Aug 2018
    • 2829
    • Steven
    • Belgium
    #16
    Thanks Andrew & Tony!
    I had a few hours today to mask and spray the 2nd camo color...
    Masking with Blu-Tack...
    Tamiya tape...
    Right after spraying the dark brown I removed the masking tape.
    I still need to add some interior green to the wheel openings...
    Perhaps tomorrow I can spray a first gloss coat for the decals...
    Thanks for reading and kind regards :thumb2:
    Steven
    • JR
      • May 2015
      • 18273
      #17
      Top marks Steven looks really good, as for that masking on the canopy I take my hat off to you !
        • 22770
        #18
        Great paint work Steven, looking very nice indeed.
        • HAWKERHUNTER
          • Feb 2012
          • 1592
          • Steve
          • Halifax, West Yorks.
          #19
          Great build thread Steven. Plane is looking awesome.
          • Steven000
            • Aug 2018
            • 2829
            • Steven
            • Belgium
            #20
            Thanks John, Ian & Steve!
            I was able to spray on the first gloss-coat this evening, hope to start with decals tomorrow! oop:
            (gloss lucky varnish, mig)
            Kind regards,
            Steven
            • yak face
              • Jun 2009
              • 13841
              • Tony
              #21
              Looking very slick Steven , how was the lucky varnish to use ? I’m wanting a good varnish that gives a nice glossy shine ,after only one coat preferably , this one does look very good . Cheers tony
              • Steven000
                • Aug 2018
                • 2829
                • Steven
                • Belgium
                #22
                Originally posted by yak face
                ... how was the lucky varnish to use ? I’m wanting a good varnish that gives a nice glossy shine ,after only one coat preferably ...
                Hi Tony,
                I think in your case the Lucky varnish might not be the best choice for you, I like it but as many of the mig range this product needs to be applied in very thin layers, and about 5minutes between coats... I also seem to get issues when after 24hours I start using MicroSet for decals, I'm not sure what happens but it looks like the MicroSet is sometimes (not always) attacking the gloss coat a little bit :thinking: . This might be caused by something else, but it looks a bit liÄ·e when you have a wet paper and move your finger over it, then you get these very fine grainy things coming loose... But it might not be the varnish, any one else who knows what I'm talking about?
                Yesterday I got the decals on, will try to get a picture online later :thumb2:
                Steven
                • Steven000
                  • Aug 2018
                  • 2829
                  • Steven
                  • Belgium
                  #23
                  Hi guys,
                  I added the decals on the P-40...
                  Lately I'm having some minor issues with MicroSet aplied onto the Lucky Varnish Gloss coat,
                  it seems to attack the gloss coat similar like rubbing your finger on wet paper?
                  I had this on my other builds too but after the matt-coat is sprayed on this is no longer visible...
                  Decal setup...
                  The decal sheet, 3 different shark-mouths are included :thumb2: ...
                  I thought the shark-mouth would be very tricky but if you take your time it's not to difficult at all.
                  They did a very good job designing the decal-shape to conform to the model.
                  All decals are on, I went for the box-art markings...
                  I applied a 2nd gloss coat yesterday so today I'll add the panel wash...
                  Thanks for reading and Kind regards!
                  Steven
                  • Steven000
                    • Aug 2018
                    • 2829
                    • Steven
                    • Belgium
                    #24
                    Hi guys,
                    Yesterday I added a panel-line wash, I used Tamiya dark brown and here and there a bit of black...
                    A did a bit of dry-brushing on the wheels...
                    Today I sprayed a few coats of 'ultra matt' Lucky Varnish, I also added the exhaust and gun shading with the airbrush...
                    I glued the tail-wheel...
                    But the hole in the fuselage was to big, so I made a stretched-sprue and clamped it around the tale-wheel as an extra support (glued)...
                    The masking was removed from the canopy, always exiting oop: ...
                    The tail-wheel still has to dry a few hours, this is what I have at the moment :
                    That's all for now, many thanks for reading and kind regards!
                    Steven
                      Superb work Steven - the canopy looks fantastic.
                      • Fernando N
                        • 2448
                        #26
                        Great looking paintwork and decals Steven:thumb2:
                        • colin m
                          • 8755
                          • Colin
                          • Stafford, UK
                          #27
                          That does look really nice. I do like a desert camo' scheme.
                            • 18908
                            That looks fantastic, great work and a great camo scheme...
                            • wotan
                              • May 2018
                              • 1150
                              #29
                              Very nice clean paint job.
                              • Mini Me
                                • Jun 2018
                                • 10711
                                #30
                                Steven, What tool did you use to apply the panel line wash? Did you thin it before or apply it neat?
                                Came out very nice. Rick H.
