Hi I'm going to build this as a comeback build, it was a present with my breakfast this morning from my good lady.
As you can see I've already started I've cleaned all the parts up ready for assembly.
[ATTACH=CONFIG]n[/ATTACH]
Painted the cockpit add a decal instrument panel.
[ATTACH=CONFIG]n[/ATTACH][ATTACH=CONFIG]n[/ATTACH][ATTACH=CONFIG]n[/ATTACH]
Assembled the two halves of the fuselage and had to re cut panel lines.[ATTACH=CONFIG]n[/ATTACH]
Assembled upper and lower halves the main wing.
I must apologise to the real aircraft builders on forum I'm just seeing if I can still glue two bits of plastic together before I go back to building my tanks so please bear with me.
Pete.
Pete.
