Zvezda 1/72 Yak-130 x 2 - A pair of Mittens!
    Looking very good and what a pace!
    I've never seen these before, but that's maybe because I don't look very hard at anything Russian. I have to say they are pretty useful looking things.
    Keep up the good work Dave!
      Well, if I can't go to my local coffee shop for my latte caffeine fix, then I may as well sit at my bench, with a poor instant coffee substitute!
      The other guys I regularly meet ( all older than me ) are of a like mind and are cutting down on public appearances.
      The Russians are worth looking at - knowing your liking for sea borne wingy things.................Click image for larger version
      Or even the Revell boxing of this model
        Painted & detailed painted the cockpit tubs, ejector seats & pilots, then fitted the tubs to the fuselage assemblies. The upper wing surfaces added - just cemented at the rear at the moment, I want to dry fit the lower wing surfaces, and see what sort of fit I have, before fully glueing.
        The pilots ( angle of photo makes them look heads down! ) - 2 in workaday green for the trainer, 2 in orange for the display crew
        I've added two BB in each nose & secured with PVA. I'll stuff the cockpit with tissue, so I can spray overall primer - the cockpit coamings, instrument panels & seated crew can be added much further on in the assembly
          Lower wings, lower engine cowls & tail planes added The step by the rudder is the recess for the large air brake, which you can show open/closed. I realise I've missed out a transparent part, on the centreline in front of the airbrake -it can only be fitted from inside, it's only a tiny beacon, so I'm sure I can make a sub.
          No problem with fit - TET wicked into the joints. Those tail planes are really thin, like little razors.
          I have to add the flaps, and pylons ( only on the trainer ) then I can think about masking/stuffing for primercoats
            Al last, I've covered up that red plastic & I now have a pair of grey mittens!Click image for larger version
ID:	1118094Click image for larger version
            Luckily I did notice that the trainer aircraft & display aircraft have different flaps - something to do with the pylons, I think.
            I have to decide what colour to do the trainer version. There is a Belorussian 4-colour camo, but on such a small aircraft that looks a little 'fussy'. The Russian AF variant is overall dark grey, and I think that will look good, when alongside the red/white version
              After letting the primer really dry overnight - the trainer was sprayed overall dark grey, and the display aircraft had the lower fuselage sprayed white.
              I'll let the white harden off overnight, then mask up & spray the red, which could be a tricky business!
              The Yak-130 is around the same size as the BAE Hawk, with similar characteristics for performance, albeit with the safety of twin engines.
                I masked up the display aircraft & sprayed Revell Acrylic 'fiery red' - the only gloss red paint I have in my paintboxClick image for larger version
ID:	1118192Click image for larger version
                My habit of decanting paint into a plastic shot glass, before thinning & airbrushing saved me a lot of hassle. I added IPA to thin - and the whole mix coagulated in a matter of seconds! Luckily I had enough paint to ditch this & try again, this time thinning with tap water,
                which worked well. Another mental warning - this time about Revell paint ( originally bought for a Ferrari F1 car ). A bit of tidying up before moving on - undercarriage next, for both models.
                • JR
                  • May 2015
                  • 18273
                  #23
                  Looking good Dave, and a new mat ! hope you didn't pay full price for it :smiling2:
                    A3 AK Cutting mat - £4.99 from John at SMS - heavy duty - good quality - I was buying some paints, so added that, as my old one was a bit shabby.
                    That red paint - a real pig to spray, and you have to take extra care in cleaning your airbrush, or it will either clog the brush, or taint your next colour!
                    • stillp
                      • 8097
                      • Pete
                      • Rugby
                      #25
                      That's a useful warning about Revell and IPA, thanks Dave.
                        Peter,
                        It's the Revell Aqua Acrylic in the square containers. The reaction was almost instant - just imagine that happening in the cup & nozzle of your airbrush! :worried:
                          These have taken a back seat whilst I have been fighting the Master Box figure, but I've managed to get the pilots installed & first pass of canopy paint. ( only dry fitted! )
                          I did find I had to cut down the base of the backseaters' ejector seat, the canopy wouldn't close over it.
