1/32 Revell Fw190 G8 'Red 12' 5./SG10
  • AlanG
    • 6296
    #61
    Well that is the wiring done. May add a couple of pipes but not sure. Depends what can be seen from the open panels. Not the cleanest job and i will most certainly do it totally different should i do this again. Lessons learned and all that. But if you don't try, you don't know.
    Time to touch up the painting.
ID:	1139399Click image for larger version
      • 18944
      I think that looks pretty cool Alan. Nice job on the knitting.
      • AlanG
        • 6296
        #63
        Cheers Tim. Bit of a labour of love and mucho swearo went on. But it feels good to have attempted it.
        • AlanG
          • 6296
          #64
          Paint touched up and started adding exhausts. Not sure if they need a little more rusting on them though.
ID:	1139478Click image for larger version
ID:	1139481Click image for larger version
          • mrtintheweb
            • May 2020
            • 292
            #65
            Looks like that engine will run with some fuel added!
            T
            • AlanG
              • 6296
              #66
              Exhausts all fitted now. Not a great fit as some of the detailing i've added is getting in the way. But it'll do for now and you'll not see much with only the top engine panels being open. Time to try and mount this engine in the bay now. Then i can start to try and make up the (apparently) very tricky designed cowling.
ID:	1139720Click image for larger version
                • 18944
                Looking better and better Alan.
                • AlanG
                  • 6296
                  #68
                  Tim. It's a shame my photographic skills don't actually capture the colours well. I added an engine wash (AK Interactive) to the cylinders and obviously the pigments to the exhausts simulating rust. In natural daylight they do look rather good.
                    • 18944
                    Hi Alan. Try photographing the engine against a lighter mid grey background. You are using a black background and the camera is trying to optimise that as a grey. The camera exposure meter is designed to make the largest area on the picture (the background) the mid tone, analogous to mid grey. It therefore overexposes the image, blowing the highs and washing out the colours and subtleties. If the background already is a mid tone it will correctly expose the image.
                    • AlanG
                      • 6296
                      #70
                      Tim Marlow Thanks for the advice regarding a white background. I think the colours are showing up now
ID:	1139832Click image for larger version
ID:	1139833Click image for larger version
                        • 18944
                        Looks much better Alan. The rust colours on the exhaust are showing the subtleties in the painting now. Just as an experiment, try to find something that is in between these two backgrounds and photograph against that (something close to Vallejo neutral grey is a good approximation). It may well improve definition yet again....
                        • AlanG
                          • 6296
                          #72
                          You go to all that effort of detailing the engine then once it's in place, you see naff all of it lol. Well at least i know it's there i suppose.
                          Wings are on too. Both the cowls and wing tops are rubbish fits. Will know better for the next one i do. Might take the locating pins off and make the wings fit that way instead. But its getting there now.
ID:	1139855Click image for larger version
ID:	1139856Click image for larger version
                          • Steven000
                            • Aug 2018
                            • 2830
                            • Steven
                            • Belgium
                            #73
                            We a
                            Originally posted by AlanG
                            You go to all that effort of detailing the engine then once it's in place, you see naff all of it lol. Well at least i know it's there i suppose...
                            We all know it's there Alan! :nerd::smiling5:
                            Looking forward to the rest :thumb2:
                            Steven
                              • 18944
                              We certainly do Steven. And we know it looks fantastic.
                              • AlanG
                                • 6296
                                #75
                                Actually if i was to have the upper gunbay open then you'd see a lot more. But as the G8 had the upper machine guns removed there is no point in showing an empty bay lol.
                                The next one i do ( a proper F8 with all that AM and a dio) will have everything on show.
