Finally looking almost completed.
Did the decals today, as a 103 squadron variant as this was the one a family member was tail ginner in completing 54 missions before the end of the war which from what I have read is good for a rear gunner.
I have to apply Matt varnish still to fully fix decals and once done put on the clear bits (canopy, turrets, front bubble for bomb aimer and nav and landing lights).
Lastly, the board it's sat on I am considering making into a base (concrete apron section) but am undecided. Was planning to sand and then apply poly filler to the top, scoring once dry to make sections and then spraying. Any thoughts? It isn't something I have done before.
AWWWWWWWEEEEEEESSSSSSSSSOOOOOOOOMMMMMMMMEEEEEEE !!
There,i said the "A Word".... but it IS ,as simple as that!
Loving that very much James,
Excellent stuff on an iconic aircraft:thumb2:
Andy
So the Lancaster is finally done (will pop photos in completed section when base is also done) and I am doing the base.
Found a piece of scrap wood and covered with poly filler, left to 80% dry and sanded roughly and scribed lines into it. As it's not completely dry some corners have broken which I quite like as it's a bit like concrete.
Given it 1 coat of black and I think will need one more before infilling centres grey and then dry brushing, varnish and then pop some static grass in the cracks.
