Tamiya 1/48 F16C Aggressor
  • Mr Bowcat
    SMF OG
    • Dec 2016
    • 4608
    • Bob
    • London
    Morning guys,
    I pulled this one out of the stash yesterday. I've acquired quite a lot of aftermarket parts so this is going to be a slow and steady build.
ID:	1119781Click image for larger version
ID:	1119782Click image for larger version
ID:	1119783Click image for larger version
ID:	1119784Click image for larger version
ID:	1119785Click image for larger version
ID:	1119786Click image for larger version
ID:	1119787Click image for larger version
ID:	1119788Click image for larger version
ID:	1119789Click image for larger version
ID:	1119790Click image for larger version
ID:	1119791Click image for larger version
    The current plan is to build it wheels up and in flight, but I may change my mind yet.
    Si vis pacem, para bellum.
  • Mr Bowcat
    SMF OG
    • Dec 2016
    • 4608
    • Bob
    • London
    I made a small start on this last night with the cockpit. Nothing fancy, just painted the tub and glued on some PE.
ID:	1119921Click image for larger version
    • Steven000
      • Aug 2018
      • 2830
      • Steven
      • Belgium
      Nice project Bob, cockpit looks great, will be following :thumb2:
      Steven
      • boatman
        • Nov 2018
        • 14498
        • christopher
        • NORFOLK UK
        SO WILL I
        chris
        • Mr Bowcat
          SMF OG
          • Dec 2016
          • 4608
          • Bob
          • London
          Cheers guys.
          • yak face
            • Jun 2009
            • 13854
            • Tony
            Great start bob , the Tamiya f16s are regarded very highly ( i mean their own tools, not the Italeri re boxes, ) it should go together with no probs . Cheers tony
            • Si Benson
              • 3572
              Cool looking bird Bob...this build is going on the watch list
              • langy71
                • 1950
                • Chris
                • Nottingham
                Good start Bob,
                i'm moving toward the finish line with this version...Click image for larger version
                • flyjoe180
                  • Jan 2012
                  • 12433
                  • Joe
                  • Earth
                  Nice start Bob, and great choice of kit.
                  • Mr Bowcat
                    SMF OG
                    • Dec 2016
                    • 4608
                    • Bob
                    • London
                    Cheers guys.
                    Chris, anything to watch out for during the build?
                    I decided to use the kit bang seat in the end, the resin one is slightly too wide to fit in the tub. After a quick test fit with the pilot (so I could get his arms glued in the right position) I hacked up the kit seat and applied the PE.
ID:	1120059Click image for larger version
ID:	1120060Click image for larger version
                    And I also started work on the first part of the intake trunking. After a few application of filler, plenty of sanding and some paint I managed to achieve a seamless joint.
                    • langy71
                      • 1950
                      • Chris
                      • Nottingham
                      nothing that jumps out to be honest Bob, just make sure you double check the instructions before you settle on a 'version', at times the various holes you'll need to drill out may be confusing...
                      p.s. you can search the aircraft's serial number here..
                      www.f-16.net/aircraft-database/F-16/serials-and-inventory/airforce/USAF/
                      here's mine.. http://www.f-16.net/aircraft-databas...-profile/2062/
                      • langy71
                        • 1950
                        • Chris
                        • Nottingham
                        Also, you may need to pick this set up, dependant on the 'Block' number of the aircraft you're doing...
                        Tamiya detail set in scale 1:48, 12621 is a NEW tool released in 2008 | Contents, Previews, Reviews, History + Marketplace | General Dynamics F-16 Fighting Falcon | EAN: 4950344126217
                        • Mr Bowcat
                          SMF OG
                          • Dec 2016
                          • 4608
                          • Bob
                          • London
                          Thanks Chris.
                          I've already researched on F-16.net, a very useful site. I'm building 86-0335 (http://www.f-16.net/aircraft-databas...-profile/2118/).
                          As for add on's, I have the Eduard body & cockpit PE set, Master pitot & AOA probes and static dischargers, and a nozzle set from A.M.U.R. Reaver. :tears-of-joy:
                          • colin m
                            • 8770
                            • Colin
                            • Stafford, UK
                            It will be nice to see this built. The F16 is probably my second most favourite jet. Even more so in an aggressor scheme.
                            • langy71
                              • 1950
                              • Chris
                              • Nottingham
                              Originally posted by Mr Bowcat
                              Thanks Chris. :smiling3:
                              excellent stuff indeed,
                              if you are using the original decals..('i'm thinking the air-frame stencils'),be wary that they are quite thick and may need shed loads of micro sol / set or future/ gloss varnish to get them to settle down properly, oh and careful reading of the decal placement sheet may be needed as a couple of them (on the canopy) aren't located correctly, but a quick 'google' for pics will see you right... :thumb2: ..
                              now then...high-jack over...
                              over to you buddy..
