Time for a quickie - zvezda 1/144 lavochkin la5 fn
  • yak face
    • Jun 2009
    • 13853
    • Tony
    #16
    Red cowling done and airframe given a coat of klear , next up the few decals then i can think about getting the canopy on . Speaking of which , i was going to cut off the locating pin and just glue the canopy on but looking at it the hole in the middle of the clear piece is visible even if the pin isnt in it ,so I decided to paint the pin so it could pass as a pilots head , just a bit of brown and flesh !Click image for larger version
ID:	1121186Click image for larger version
    • yak face
      • Jun 2009
      • 13853
      • Tony
      #17
      Decals on , I decided to use the spare number 1s and 7s to make the two white stripes on the tail , these still need a bit of touching up once they’re dry . Next is a Matt coat then it’s on with the canopy and a very tricky frame paint - obviously it’s too small to mask so it’s going to be a hand painted job . The Lavochkin radial engined fighters and a few of the polikarpov too had a bright metal band ( sometimes two or parts ) round the circumference of the cowling which is a very prominent feature of these aircraft and something I want to try and replicate. I’ve got some self adhesive chrome effect tape ( actually Xmas wrapping tape ) that I’m going to stick onto non stick backing paper and try and cut into very thin strips and apply , we‘ll see how successful that is tomorrow ! Cheers tonyClick image for larger version
ID:	1121197Click image for larger version
        Looking good Tony :smiling3:.
          • 18932
          Nicely done Tony. Always think adding decals to an aircraft brings it to life....bit like doing the face and eyes on a figure.....
          • yak face
            • Jun 2009
            • 13853
            • Tony
            #20
            Well I found the xmas tape and stuck it onto a bit of sticky label backing paper . I managed to cut a very thin strip and this was stuck round the back edge of the cowling and a couple of short pieces just behind that . It worked very nicely and gives a good representation of this distinctive feature . Ive glued the canopy on and given the frames a first coat of colour roughly by hand . Once theyve had a second coat I can clean up the edges with a cocktail stick and itll be ok . I also tidied up the two stripes on the fin , touching up the edges with white. Click image for larger version
ID:	1121301Click image for larger version
ID:	1121302Click image for larger version
ID:	1121303Click image for larger version
            • adt70hk
              • Sep 2019
              • 10428
              #21
              Tony
              That really has come on very nicely and as you say the 'pilot's head' looks ok from a distance. Well done!
                • 22771
                #22
                Cracking work Tony
                • yak face
                  • Jun 2009
                  • 13853
                  • Tony
                  #23
                  After a final push im calling this done. The undercarriage , pitot ,aerial have been fitted and its all had a coat of Matt varnish (galeria , sprayed ).The aerial and pitot were made from plastic card and wire respectively , the kit ones were a bit overscale but I mainly replaced them because I broke them off and lost them !! I added the nav lights with the tiniest drop of red and green paint , and an aerial wire from my mrs hair. heres a couple of pics to finish this thread and I'll put up a completed one with them all on , cheers tonyClick image for larger version
ID:	1121399Click image for larger version
                  • outrunner
                    • Apr 2019
                    • 2420
                    #24
                    Looking very good, I doubt I have the dexterity to work at that scale.
                    Andy.
