Bf 109 in the Russian mud (1/48)
  • Steven000
    • Aug 2018
    • 2830
    • Steven
    • Belgium
    Hi guys,
    I already did 2 Bf109F-kits from ICM in the past (link), although these are cheap kits they can be turned into nice models with a bit of extra work.
    I still had this one in the stash, it's the R6 version with canons under the wing...
    Box-art :
    I would like to make a small dio with the model, based on these pictures :
    This would be a G2 'white 6' with wing canons in the Russian autumn mud,
    I assume this 109 was parked for cover into a bomb-crater which got flooded overnight...
    I don't have to worry about the cockpit interior or canopy-masking :thumb2: ...
    The bottom engine cowling and spinner-front-disk appears to be yellow, the rest of the spinner is a black&white.
    Some nice mottling on the nose...
    Sprue-shots :
    Same soft sprues as last time, all parts need a bit of cleaning-up...
    This sprue wasn't included in the other ICM kits, a nice set of bombs, 2 external fuel tanks and the R6 wing-canons...
    Clear parts.
    That's all for now,
    Thanks for reading, have fun, stay safe & kind regards!
    Steven
  • Mini Me
    • Jun 2018
    • 10711
    Hi Steven, That looks like a very interesting topic for a Dio. In looking at the pictures, I'm thinking that the 109 might be parked in a man made revetment. The height from both camera angles seems too uniform in appearance. just a thought.
    :smiling2: Rick H.
    • Steven000
      • Aug 2018
      • 2830
      • Steven
      • Belgium
      Originally posted by Mini Me
      ... In looking at the pictures, I'm thinking that the 109 might be parked in a man made revetment. The height from both camera angles seems too uniform in appearance. just a thought ...
      Thanks Rick!
      Yes, you might be right, I can image there would be lots of shovels around too :smiling6: ...
      I've put the model together this week, no need for a cockpit or engine :thumb2:...
      As before there is some scraping needed and the nose was build up with the engine panels...
      Again I drilled out the solid-molded nose-canon and replaced it with a plastic tube...
      Under the tarp I still need the basic shape of the canopy,
      so I glued the clear-parts in place but replaced the box-shaped piece with plastic-card, this way I have an extra spare one for future builds.
      Based on the images the radiator-flaps were opened 'full' and the middle-flaps lowered 'minimum'...
      In the picture I noticed that the model has two missing air-intakes,
      so I shaped a piece of sprue into a 'suppository' (1), then cut that into fragments (2) and glued them onto the nose (3)...
      The tarp was made from a layer of tissue...
      Then the tissue was soaked in diluted wood-glue and put onto the fuselage, a bit tricky...
      I wasn't able to replicate the image exactly because the wet tissue was too fragile to manipulate further, but I think it will work ok...
      Because the kit has these 'soft-plastic' parts the wing-canons were too flexible to work with. (1)
      So I've cut them off, drilled out the plastic (2) and glued some steel-rods in place with the same thickness :thumb2:...
      Some separate parts on wooden-sticks for painting...
      This evening I sprayed a coat of black primer, the tarp will be better visible in the end though ...
      Thanks for reading, kind regards & keep safe!
      Steven
      • adt70hk
        • Sep 2019
        • 10422
        Steven
        Nice start and nice not to have to worry about the inards!
        Keep up the good work.
        • JR
          • May 2015
          • 18273
          Russian mud :nerd:caught my attention Steven, great idea.:thumb2:
          Definitely will follow please .:nerd:
          • Mini Me
            • Jun 2018
            • 10711
            A well thought out approach Steven, I think that tarp is just right and a good bit of insight to save the canopy for a spare.
            I knew JR would be along when "mud" was mentioned. I hope there is plenty of coffee as he always gets a little "whiney"
            if there are no refreshments. :crying:
            Rick H.
            • Steven000
              • Aug 2018
              • 2830
              • Steven
              • Belgium
              Thanks guys!
              Some slowly progress on the 109,
              I sprayed the underside in an Rlm76 and highlighted some panels roughly...
              Then I added some freehand camo with rlm74/75 on the wings and I tried a few different things on the fuselage as well...
              I tried to draw and cut out a mask from Tamiya-tape, based on the '6' visible in the images. A bit too 'bold' (font) but it is what it is...
              Here I masked the yellow band and white six, the yellow panels on the underside are masked too...
              Underside-parts sprayed in yellow...
              Here I had some paint chipping off when removing the '6' mask, the mask was a bit fragile so I didn't remove the tape-stickiness on my skin...
              Underside...
              Some masking of the spinner, based on the images...
              Spinner painted...
              At the moment I got this, the tarp is painted in an rlm02 color, it was probably a darker color in the images, but I don't know what would work best...
              Next is a gloss coat and some decals...
              Thanks for reading and keep it safe!
              Steven
              • Mini Me
                • Jun 2018
                • 10711
                That is just right Steven. The camo. is top drawer and you are on your way to a great looking diorama. I am anxiously awaiting the next phase of this project. Rick H.
                • Jack L
                  • Jul 2018
                  • 1273
                  • Cheltenham
                  Looking really good Steven!
                  • Jason Crausby
                    • 658
                    Top notch!
                    Jason.
                      That tarpaulin has worked out a treat.
                      • john i am
                        • Apr 2012
                        • 4019
                        Paintwork looking great.
                        • dave
                          • Nov 2012
                          • 1829
                          • Brussels
                          Coming along very nicely
                          • scottie3158
                            • 14216
                            • Holbeach
                            I like this all looking very nice the tarp looks great.
                            • langy71
                              • 1950
                              • Chris
                              • Nottingham
                              Wow, an excellent build so far, really love how you've got the sit of the tarp looking spot on.. :thumb2: :thumb2: :thumb2: :thumb2:
