Bf 109 in the Russian mud (1/48)
  • JR
    • May 2015
    • 18273
    #16
    That's looking brilliant, wish I could cut out as good as that Steven. Tarp is the dogs !
    • rtfoe
      • 9099
      #17
      Late in Steven but when I read "dio" I got interested. Nice idea and the tarp looks wicked man. :thumb2:
      • colin m
        • 8768
        • Colin
        • Stafford, UK
        #18
        Great work Steven. I would have loved to see that engine start in the first picture - just me being silly.
        • Steven000
          • Aug 2018
          • 2830
          • Steven
          • Belgium
          #19
          Many thanks for the comments guys! :thumb2:
          This week our washing-machine broke down, it didn't want to drain and gave an error like 'drain filter full'...
          But the machine is only 1 year old and the filter was still shiny and clean!
          I decided to take a look inside to disconnect the drainage-hose connected to the drum,
          so we could drain the machine (because the door remains locked when water is inside :astonished...
          About 10 liters of water ran out (yes that plastic box could only take 2 liters... oop
          and guess what... A D*MNED SOCK was stuck inside the drain-hose !!!
          I was happy to find the problem but I'm not planning to lay down under the machine every week :thinking:...
          So with that resolved I could get back to my desk :relieved: ...
          Here's another update :
          I've added some decals, sprayed another gloss coat and just finished the panel-wash...
          When wiping off the panel-wash excess I always use a paper-tissue or a cotton swap, but those don't last long...
          Anyone here who knows a better alternative ?
          I used a swastika from a 'swastika-sheet' and also added a 'horizontal white stripe' on the yellow band, based on the images...
          Here I just added the panel-wash, next is a matt-coat...
          Next is a matt-coat...
          Thanks for reading and keep it safe!
          Steven
          • Mini Me
            • Jun 2018
            • 10711
            #20
            That is looking the bomb....glad you were able to sort that sock eating washing machine! Damned unruly thing if you ask me! :thumb2:
            Rick H.
            • Jack L
              • Jul 2018
              • 1273
              • Cheltenham
              #21
              Absolutely fantastic...explains why so many odd socks lying around.
              Model isn't bad either!
              • Steven000
                • Aug 2018
                • 2830
                • Steven
                • Belgium
                #22
                Thanks guys!
                I started working on the base, I think Rick was right about the revetment being man-made,
                so I tried to find some pictures of German revetments...
                This one seems to be well made, but looking at the Emil and geometric shape of the sand-castle I assume it's an early-war one...
                This is an aerial-photo in Germany, 1944.
                These revetments seem easier to make when you're far from home and things aren't going very smoothly ...
                'Available space' to store a diorama is always a problem, so I decided to make it as compact as possible...
                I used this blue-foam-plate that I saved from packaging. Took my some time to sort out the shape...
                I used 6mm MDF for the bottom-layer, to keep things flat and sturdy ...
                Shaping with a knife ...
                Sanding...
                Backside...
                A mixture of sand was then added with wood-glue
                Most of the sand was shaken off, then I gave it 2 coats of (Spray can) primer to fix it all in position...
                I made some cutouts for the wheels...
                Test-fit with the 109...
                The plan is to use 1-2mm of Vallejo Still Water in the end to make the pool...
                That's all for now, I'm doing night-shifts again so probably not much progress this week.
                Thanks for reading, have fun and keep it safe!
                Steven
                • scottie3158
                  • 14216
                  • Holbeach
                  #23
                  Steven,
                  This is looking really good.
                  • dave
                    • Nov 2012
                    • 1829
                    • Brussels
                    #24
                    Coming on nicely
                      More fine work Steven, and great save on the washing machine - or problems come from my son's pesky plectrums that he tends to hide in his clothes.
                      • colin m
                        • 8768
                        • Colin
                        • Stafford, UK
                        #26
                        Brilliant work, this is looking really nice. As for removing a wash, I find kitchen roll is a lot stronger. I wonder if your washing machine is related to the carpet monster. They both like consuming 'things'.
