Airfix 1/72 Dorner Do17Z
  • stillp
    • 8093
    • Pete
    • Rugby
    This is going to be my next victim:
    Hmm, can't attach files. I'll wait until John gets that fixed.
  • stillp
    • 8093
    • Pete
    • Rugby
    Right, seems to be fixed now, thanks John.
    I bought this about two years ago, quite a bargain considering it's a 2014 new tool.
    Four sprues in the usual light grey plastic:
ID:	1122222Click image for larger version
    Good detailing and I can't see any sink marks. No doubt they'll show up when I start painting! Some VERY fragile looking parts so I'll have to be less clumsy than usual/
    Nice Cartograf decals, with lots of stencils, but no swastikas, and a good clear shiny clear sprue.
    I've ordered a set of canopy masks.
    • adt70hk
      • Sep 2019
      • 10409
      Interesting kit. I've bought a couple of the new tool kits since coming back to the hobby and like them a lot. Will be following this one with interest.
      The only problem I have is that Vallejo light grey primer is almost exactly the same colour of the plastic Airfix use! Next time I'll add a drop of black to darken it up.
      Good luck with the build and especially that glass!
      ATB
      • yak face
        • Jun 2009
        • 13841
        • Tony
        That looks a beautifully tooled kit pete, and a bargain at a tenner .Some very fine details - weighted tyres , dropped flaps , very tidy looking cockpit and even four mesters too ( with seperate arms!) Good idea with the canopy masks too , I wouldnt fancy trying to mask all those little panes in 1/72 by hand ! Cheers tony
        • colin m
          • 8755
          • Colin
          • Stafford, UK
          Nice one. ยฃ10.00 was a great price. Looks good too.
          • stillp
            • 8093
            • Pete
            • Rugby
            Thanks for the comments folks. I haven't done much on this, I've been busy on the 1:1, changed the gearbox and overdrive oil, topped up the diff, found the source of a small but annoying water leak, took the sump off to change the gasket.
            I did manage to get the first three parts - support frame for the pilot's seat - assembled:
            I've done a bit more since taking that photo, the seat and control column are attached and it's had a coat of paint. Just about everything internal is in RLM02 according to Airfix, and that can't really be argued with, so the sprues have been cleaned up a bit and had a coat of Vallejo 71044.
            Here's the undercarriage - this is going to be fragile!
            Should get some more done tomorrow.
            • yak face
              • Jun 2009
              • 13841
              • Tony
              Nice start Pete , three parts just for the seat frame !? If thatโ€™s anything to go by the cockpit should be very busy ! The undercarriage looks fragile now but I reckon once itโ€™s all together youโ€™ll be surprised at how strong it is . Cheers tony
              • stillp
                • 8093
                • Pete
                • Rugby
                This cockpit is very fiddly. I'd glued the pilot's seat to the support frame, but had it too far back, so had to remove it. Actually that wasn't a bad thing, as without it I could see where the support
                frame is supposed to fit to the sidewall
                .Click image for larger version
                That part that looks like a steering wheel was hitting the back of the seat before.
                  That looks like a well-detailed kit right out of the box. Iโ€™m wondering why the struts are there on the fuselage sides, where the wings go. Will they be visible though an open bomb bay?
                  • HAWKERHUNTER
                    • Feb 2012
                    • 1589
                    • Steve
                    • Halifax, West Yorks.
                    Looking great Pete. Hard scale to work with.
                    • stillp
                      • 8093
                      • Pete
                      • Rugby
                      Yes, it will Jakko. Might just be visible through the ventral gun bay as well.
                      • stillp
                        • 8093
                        • Pete
                        • Rugby
                        Plodding on with this. Slow progress as it's a case of fit a part, touch up the paint, let dry, fit another... The crew compartment is certainly detailed:
ID:	1122898Click image for larger version
ID:	1122899Click image for larger version
                        The one of those wickerwork seats is a bit slanted, but I can't see what I've done wrong - the backrest of the seat hits an item on the sidewall.
                        Decal is drying on the IP at the moment.
                        • colin m
                          • 8755
                          • Colin
                          • Stafford, UK
                          Nice work on a very well detailed 'pit.
                          • topgazza
                            • Jan 2020
                            • 640
                            Sometimes that happens with the extra seats. It did on my 111. But that is a seriously detailed cockpit pete. Great, patient job so far
                            • yak face
                              • Jun 2009
                              • 13841
                              • Tony
                              Great job pete , i never realised there were four crewmen crammed into the cockpit , not much chance of social distancing ! Cheers tony
