I have used c.a on the last section of the fuselage bottom. I then cemented a piece of plastic sheet inside to strengthen the join. I will have a spot of filling and sanding to do there but overall it is not too bad.
I have been getting on with odd sub assemblies and decided to cement the gun covers into place. I suspect that although providing for the option Airfix expected the panels to be left open and did not pay too much attention to the fit of these panels.
To get them to fit evenly I sanded the edges, creating a bevel. I had to be careful not to sand the top edges of the covers as they fit perfectly
I still found an issue on the corners and I resolved that by carefully cutting away the ‘ridge’ in the corners.
In the pic above the top left one is removed. I also cut away a chunk from the bottom left and the section in the middle.
After that, a perfect fit.
Tomorrow I will tackle the upper front fuselage, the area worse affected by the warping.
