Junker Ju52 Build
There is a nice solution for rotating pictures , described very well at the following weblink @ www.ivertech.com/Articles/Image-Rotation-Issue-With-Windows-10.aspx
Ps ... Lovely work so farComment
i presume this only works if you up load your photos to windows first but I have been uploading straight from my iPhone to the forum direct. There isn’t any options to rotate that I could see?
[/QUOUTE]Comment
Apple’s help pages. You don’t even need to switch to Photos to do this: after taking a picture, tap on the little preview it shows in the sidebar, so you get to see the whole photo (you can flick through all the pictures you recently took here, BTW) and tap the Edit button at the top of the screen.
(I take all the photos I post on this forum using an iPad, and do these kinds of corrections on that as well to make them more presentable.)
Something I forgot to mention in my previous message is that upside-down photos often result if you hold the phone with the screen facing up, because then it can’t work out which way “up” is for taking photos. What you need to do is tilt the phone first so that the screen is vertical and towards you, which will rotate the controls to put them the right way up, and then hold it flat — but don’t tilt it so far that you see the on-screen controls rotate to face another direction. If they do, hold it vertical again.Comment
carlComment
You can rotate the images directly on the phone, as well as crop them, correct perspective, and much more, as explained on
Yes, I think the Eduard can be a marmite thing but I have found the main cockpit controls to look good on most of the aircraft I have built so far. Some of the very small details just don’t seem worth the effort to fit as you need a microscope to see them and they just dont seem worth the stress fitting. I attend to cherry pick the bits I like that add reasonable improvement to the standard model detail (at least in my humble opinion).Comment
I’ve managed to get a few spots of glue when glueing roof part down. Because the fuselage is serrated I was wondering what the best way to clean of any excess glue was. Sanding would not really do as is flatten the corrugated detail.
[ATTACH]391335[/ATTACH]Attached FilesComment
