Gern's 1/32 Trumpeter F-105G - A Sad End.
  • Gern
    • 9220
    #106
    Not the best pictures, but they do show you sometimes can't have enough clamps.
ID:	1133606Click image for larger version
ID:	1133607Click image for larger version
    Apart from the front part of the cockpit, I think I've got the fuselage seams sorted - primer will show anything I've missed. I've used Tamiya putty for the first time and I'm impressed. It has a much better 'grab' to the plastic and is slightly thicker than the new formula Squadron Green - which is good as I'm going to have LOTS of filling to do along the wing edges.
    Does anyone know what colour I should use for FOD covers on the intakes? If my ideas about this pan out, I'll need to make some.
    • boatman
      • Nov 2018
      • 14497
      • christopher
      • NORFOLK UK
      #107
      HI Dave FOD cover are normaly red an did you have a good kip ?
      • Gern
        • 9220
        #108
        Thanks Chris, red it will be. I woke up after about 5 hours which is plenty. I'll go for a week on just a few hours a night, then have a 'proper' lie-in for 10-12 hours! One of the perks of being retired and living alone.
        I've been thinking about resurrecting an old unfinished build (you got to go a LONG way back in my threads to find which one! I know you're not interested in my stuff so I won't bore you with the details :smiling: ) once I've done this one. I bought a small lighting set which works fine but I'm wondering how to fix the miniature LEDs into position. Can I use a drop of CA or do I need something else?
        • Gern
          • 9220
          #109
          Thanks for the 'Like' Chris, but you didn't answer my question. Can I use CA to fix LEDs in place - obviously on the wiring rather than on the LED itself.
          • boatman
            • Nov 2018
            • 14497
            • christopher
            • NORFOLK UK
            #110
            HI Dave fixing the led's i use super glue to fit mine but you must be carefull not to pull on the wires as if they are the 2mm ones like i use i look through my magnifirer an put a small drop of S/G on the backs of the led's to hold the wires in place then a little more to fix it in postion where you want it to go easy peasy
            chris
            • boatman
              • Nov 2018
              • 14497
              • christopher
              • NORFOLK UK
              #111
              HI DAVE :thinking: well whats happening on this is there a srike in the building plant ?:rolling:lol :upside::smiling::smiling:
              chris
              • boatman
                • Nov 2018
                • 14497
                • christopher
                • NORFOLK UK
                #112
                WELL Dave whats happening ? as ive got my intrest back lol
                chris
                • Gern
                  • 9220
                  #113
                  Yeah. Well you see it's like this Chris.
                  Last weekend I heard Clyde (he's the scruffy one remember?) hammering and banging on the cat flap to be let in. It's one of those electronic ones which picks up a signal from a microchip - or at least it was. It was broke and didn't work for either of my cats. I took it out of the door and took it to pieces to find one of the connecting wires to the motor had come adrift. It wasn't just the soldered bit, it was the little brass plate that the wire was soldered to. Not being any sort of electrician, I asked my brother-in-law to have a look. He got the motor working but when I put it near the cats to try it, it still didn't work so off to the pet shop for another. That cost me about ยฃ60.
                  It's a Georgian type panel door and the new flap is smaller than the old one and leaves huge gaps around the opening; so I've had to make a couple of panels to fit either side of my door. I've used some Palfoam which is a strong plastic foam material. It's great stuff but needs a strong solvent type adhesive so I can't fit them just yet, I'm waiting for some proper adhesive to arrive. Meantime I've got the flap taped to the door with Cellotape. I'm still having to help Clyde with it. The sensor for the chip is tucked right inside the frame and the range is very short. The cats have to use their head to push the door open. Clyde is still trying to open it with his paws so his head doesn't get close enough to operate the sensor!
                  Monday I was working with PJ all day so didn't get anything done for myself. I did a bit of clean-up on my Thud on Tuesday and was going to start filling the gaps on the wings. This was about 2:30 on Wed morning - still my Tuesday night as you know - when my smoke alarm went off.
                  Any idea how loud that is in the wee small hours of the morning? Went into the kitchen to find smoke pouring out the back of my tumble dryer. Turned it off and checked for flames - no sign so I opened the door and window to clear the smoke. Found a stick to turn the ceiling mounted alarms off - didn't work. Turned off all the mains power as the alarms are mains powered - didn't work. Comes a knock on the front door, both my neighbours asking if I'm OK. Apologised profusely for waking them and had to wait for the smoke to clear enough for the alarm to stop. Only took about 10 minutes so not too bad.
                  Spent Wednesday and Thursday looking around for a replacement tumble dryer. Ain't they expensive?! Found a second-hand one from a local shop for ยฃ130 so saved a bit on that.
                  So that was two things yeah? I'm sat there waiting on Friday for shoe number three to drop. Nothing happened so I'm thinking that the old superstition about bad things happening in threes was just a myth. I shoulda known better!
                  Went to collect my new tumble dryer this morning and the guys in the shop kindly loaded it into the back of my motor. No problems 'til a nice kind gentleman waved me out of a side road on the way home. Not wanting to keep him waiting, I put my foot down a little to pull out of the side road. Now I need a new rear window on my motor!
                  I'm gonna either have to light more candles to the gods or get bigger ones!
                  Still, every cloud you know? P'raps that will be it for the bad luck for a while. Meanwhile it's gettin' a bit warm in here 'cos of all those candles - off to open a window!
                  • stillp
                    • 8096
                    • Pete
                    • Rugby
                    #114
                    You're having a hard time Dave! What make tumble dryer was it - I know there are recalls for several makes due to fire risk.
                    • Gern
                      • 9220
                      #115
                      It's a Hotpoint - one of the ones that was recalled. I bought it second hand about 8 years ago and I've only ever used it while I've been at home - just in case. I suppose it's now debatable whether the ยฃ100 I saved by buying second hand was worth it.
                      • boatman
                        • Nov 2018
                        • 14497
                        • christopher
                        • NORFOLK UK
                        #116
                        OH DEAR Dave very sorry to hear of your misfourtunes i think if you get back to modeling you'll beat your bad luck an it will just seem like a bad nightmare dream an jen an i wish you all the best from now on so get a lucky charm an stick in your pocket
                        • boatman
                          • Nov 2018
                          • 14497
                          • christopher
                          • NORFOLK UK
                          #117
                          WELL Dave when will you get back to this build ?
                          chris
                          • Gern
                            • 9220
                            #118
                            Back on it today Chris. I'll have some pics later - maybe even with wings on!
                            • boatman
                              • Nov 2018
                              • 14497
                              • christopher
                              • NORFOLK UK
                              #119
                              HOOOOOORRRRRRRRAAAAAAAYYYYYYYYYYY lookin forward to hear an see something from you dave as you make me laugh an i certainly need a good laugh today
                              chris
                              • scottie3158
                                • 14208
                                • Holbeach
                                #120
                                Dave,
                                lets hope that's the end to the run of bad luck. Glad to see your back at the bench.
