Sorry to hear youre having a bit of bad luck mate but look on the positive side , the smoke alarm did its job and saved things from being a lot worse. The main thing is youre ok , cheers tony
Gern's 1/32 Trumpeter F-105G - A Sad End.
Thanks guys. Cat flap done and new rear window fitted so back to normal.
A bit more progress. I was hoping to have both wings fitted but they need to be pulled tight against the fuselage to close the gap. Rather than trying to close the gaps by pulling both wings together, I'm doing them individually. That way, I have a solid bit to fix my tape to and hold the wing while it sets. Once set, it will give me a solid base for the tape on the other wing. The nose cone went on with no need for filling and the tailfin fitted with only a tiny gap which I filled with Vallejo putty. I've also knocked up a couple of FOD covers from some sheet balsa.
[ATTACH]400731[/ATTACH]
[ATTACH]400732[/ATTACH]
[ATTACH]400734[/ATTACH]
Terrible pics I'm afraid.Comment
[ATTACH=CONFIG]n1134663[/ATTACH]
[ATTACH=CONFIG]n1134664[/ATTACH]
[ATTACH=CONFIG]n1134665[/ATTACH]
chrisComment
Hi Dave
They say bad luck comes in threes so hopefully you're ok now for a while. There seems to be a lot of problems with tumble driers. Ours was replaced as it was on a recall list. We only use ours now when we are actually downstairs with it.
JimComment
I was hoping to beat you to it Chris! I have made some progress. My wingy thingy now has wings!
That's a 12" (300mm) rule.
The colour on these looks OK
There's a couple of sticky-out bits (technical term) to add, and a smear of filler in the wing joints, but I'm hoping to get on to masking and painting on Tuesday.Comment
Sorry my pc is playin up i'll reprint the post
Well Dave im glad you have got over your bad luck an you are building again as some of your terms make me laugh (eg like the sticky out bits ) gave me a good giggle an yes it is a biggee wingy thingy an it look like you are doin a good job but when is this cunning plan comin ?
chrisComment
Forgot to mention. The small masking tape strip has the part number for the tailplane so I didn't get them the wrong way round. I think they're both the same anyway, but better safe than sorry.
As for my cunning plan, you're going to have to wait and see. You should know that cunning plans sometimes take a while to come to fruition, although I'm not so sure now that it is actually a cunning plan. I've found a piece of MDF I can use as a base but it's 24"x18" (600mmx450mm) - and I have absolutely nowhere in the house to put it when it's finished!Comment
Great progress Dave and good to see you got the wings on her ok. Not sure about your fingernail polish though.....A little too bright I think.....
I'd say it's time to get yourself a new ruler. Maybe a yardstick would do the trick being it's such a big bird and all........
AllenLife's to short to be a sheep...Comment
