Modelling the Mark 1 A spitfire in 1/18 scale
  • ozdell
    • Apr 2020
    • 365
    #91
    Originally posted by adt70hk
    Good to see you back at the bench Tony after your health scare.
    That really is going to look good once finished.
    ATB
    Hi Andrew, many thanks good to be back, posting a video with lots of working features. Tony
    • ozdell
      • Apr 2020
      • 365
      #92
      Hi all, is time to finely ad a video of all the working features of the spitfire, I hope the stand doesn't cost too much..
      enjoy <Tony cold wet down under
      • adt70hk
        • Sep 2019
        • 10409
        #93
        Oh my!!
        • ozdell
          • Apr 2020
          • 365
          #94
          Oh my!!
          Thanks Andrew, Tony
          • GerryW
            • Feb 2021
            • 1757
            #95
            Wow! That certainly looks great.
            • ozdell
              • Apr 2020
              • 365
              #96
              Hi Gerry, I thought that video blow you away, should of posted it a while back a matter of finding, it, pick up issue 34 today will complete underneath the central fuselage and wing.. have to wait to see what next weeks set of parts , Tony
              • ozdell
                • Apr 2020
                • 365
                #97
                The plane is finely starting o take of a spitfire with at last the nose and prop is screwed in place, this weeks parts didn't do anything waiting on next weeks parts the cradle to do with the landing gear motor, one motor operates both landing gear by a wire set up
ID:	1154977Click image for larger version
ID:	1154978Click image for larger version
ID:	1154979Click image for larger version
ID:	1154980Click image for larger version
                IN the last pic you will see the wire I am talking about, ,be a while before I can test it, need the remote .
                Tony from cloudy wet down under
                • boatman
                  • Nov 2018
                  • 14456
                  • christopher
                  • NORFOLK UK
                  #98
                  HELLO Tony spitty lookin good bet thats getting heavy now as it all metal how many more mags do you need to finish it ? an hope you feel better now
                  chris
                  • ozdell
                    • Apr 2020
                    • 365
                    #99
                    chris
                    Hi Chris, thanks, will have to make a stronger cradle for the spitfire to sit in while adding wiring and gun plastic tubing., you will see in the fist pic the cardboard cradle isn't much chop . Tony
                    • GerryW
                      • Feb 2021
                      • 1757
                      #100
                      Looking good :thumb2:
                      Try painting the cardboard with a PVA water mix - it'll strengthen it up no end when dry
                      • ozdell
                        • Apr 2020
                        • 365
                        #101
                        Hi Gery , thanks for the advice I just head to Bunning they have plenty of small boxes I can make into a dissent cradle. Tony
                        • ozdell
                          • Apr 2020
                          • 365
                          #102
                          I am all ready to go to make a start on putting the landing gear motor into the cradle, first have line up a wire cable through the motor to the landing gear, going to be fun.
                          That will be tomorrow afternoons job
                          TonyClick image for larger version
                          • adt70hk
                            • Sep 2019
                            • 10409
                            #103
                            Tony
                            Good to see you back at the bench.
                            Hope the latest trip to hospital was not for anything too serious.
                            ATB.
                            • ozdell
                              • Apr 2020
                              • 365
                              #104
                              Tony
                              ATB.
                              Thanks Andrew
                              • ozdell
                                • Apr 2020
                                • 365
                                #105
                                chris
                                Hi Chris, yeah she be a heavy plane with all those metal parts, got to make a cradle so I can lift the prop up off the table while working on the wings.
                                How are you and Jenny copping with the humid summer trouble being close to water all around you, Tony
