Revell ( Eduard ) 1/48 Albatros D.III
    Carl,
    the HP 0/400 is still a nice model - I seem to remember it was the first biplane I ever rigged, and the first that actually made provision for it - holes already for threading! Something I hadn't come across before!
    • Defiant911
      • Feb 2020
      • 640
      #32
      Carl,
      That would be nice if the holes are there. I’m yet to try rigging on any model so another neW experience .
        Carl,
        just looked at the latest instructions - the holes & the rigging instructions are still there - all you need is the thread!
        • Defiant911
          • Feb 2020
          • 640
          #34
          Carl,
          It’s been taking me so long building this Queen Mary ship that the stash has grown. I’ve even given my son the odd one to keep him going.
          One thing I have found is how bad my brush work is. No matter how hard I try it seems impossible to get the white paint on cleanly. Have to get to about third coat before it resembles good covering and even then it’s not that pretty.
          sorry, I’m going off topic now...
          • Lee Drennen
            • 7711
            #35
            Dave nice work on the Wood very convincing
              Carl,
              white is a difficult finish - I'm afraid I wouldn't attempt to brush paint such a large area. I use Stynylrez white primer through my airbrush & even then sometimes needs 2 coats to really cover evenly. You probably have to do a whole load more masking, but I find it less aggravating!
                Not a lot done today - I always seem to get sidetracked at the weekend..............
                Lower wings added - I used Revell Contacta for the initial grab, then after an hour or so ran TET into the joint. I'll let this really set overnight.
                You can use CA to give strength, but I prefer to use something which gives me wriggle room, in the unlikely event I make a mistake (!!!!!!) :rolling:
                Tomorrow, I'll run a drill through the rigging holes & clean out the strut attachment points - it's far easier to do it before adding the top wing.............
                  Adding the wings........................Click image for larger version
                  Upper wing taped down & outer 'v' struts added using Revell Contacta ( slow drying ) . The centre section struts are added, also using Contacta - roughly getting them at the right angle. I waited for about 20 minutes, to let the glue to begin to harden.
                  Putting drops of Contacta on all the strut attachment points - I offered up ( down ) the lower wing & fuselage, locating the centre section struts first, then springing the 'v' struts into their holes, using tweezers.
                  I then tiptoed away for an hour or two.....................
                  I returned, released the D.III & confirmed that all struts were in their holes. I then added just a drop of TET to each location to give a better bond. I'll leave this overnight, before I think about rigging.
                  I leave the undercarriage until last - it's easier to be able to put the D.III down flat, top, or bottom, when rigging etc., without having to worry about potential fragile bits.
                  • Swagman 070
                    • 144
                    #39
                    You've done a fabulous paint job Dave. Wood grain looks amazing.
                      It took quite a few attempts, and thanks to the gloss varnish over the basecoat, I was able to wipe off poor efforts, and start again. I find it difficult to know when to stop, there's always that temptation to do just a little bit more! Judging by the number of positive comments, I think I managed to stop myself in time. My main goal was to do the wood effect with the water based acrylics, - I'd seen loads of 'how to's ' , but they all used oils, and I prefer the short drying times of acrylics.
                      I'm currently blogging the Fokker Dr.I Triplane, and I'm going to use a similar technique for the streaky upper surface camo - it should be easier, there's only one colour over the basecoat.
                      • Jack L
                        • Jul 2018
                        • 1274
                        • Cheltenham
                        #41
                        That wood effect is fantastic Dave. One to be proud of!
                          I'll second Steve on that point, Dave. You've done a very realistic job.
                          • yak face
                            • Jun 2009
                            • 13852
                            • Tony
                            #43
                            Looking excellent dave , cheers tony
                            • adt70hk
                              • Sep 2019
                              • 10428
                              #44
                              Looking very good indeed. That really has come together nicely.
                              ATB
                                Half the rigging done - that's enough of that for the day, my hands have started to tremble, through concentrating on such tiny actions....
                                In close up, those 'wires' look huge - not so bad in real life!
