I sat down to start this kit at 9pm and at 9.20 I am posting this wishing I had not bothered to buy this crappy fourth rate Revell kit. Almost all that 20 minutes has been spent looking through the sprues for the five parts needed for step one, well I found three of them I suppose.
I really don’t know why I bought it, Revell never fail to disappoint with their cheap plastic, poor engineering and thoughtless production.
Rant over, let’s me explain properly why I am so disgusted not only with Revell but all those who did so called reviews of this shoddy kit.
The box
[ATTACH]399420[/ATTACH]
Look at step 1, just a mere five parts, four of which are pictured.
[ATTACH]399423[/ATTACH]
The first thing I noticed is how the sprues are not identified in the instructions. That means that you have to search every sprue for every part, the parts are not even grouped, part 1 is on the same sprue as part 108! part 7 is on another sprue and It’s a separate sprue to part 8, no picture so you cannot identify it by shape and, what is more which part applies to the early version I am building? no hint at all.
It gets worse, there are two more parts in step 1, two numbered 6. But where are they? I searched every sprue three times looking for them, then I looked closely at the sprue diagram in the instructions, you need a magnifying glass to read the numbers incidentally. No sign at all.... no parts.
See for yourself.
[ATTACH]399421[/ATTACH]
So what next I wonder. I can live without the pedals in the cockpit but this does not bode well for this build, just step 1. At least even Kittyhawk did not cock up that quickly. Unbelievable.
This is not an old kit. It was released in 2014.
Revell really should stop producing cheap shoddy crap like this.
OK it is only £23 but so what? Better that they charged a bit more and actually produce something worth buying.
This is where I would say that I will not buy a Revell again but I stupidly also bought their new tool Spitfire II with a lot of resin to correct its many errors and build a Mk1 as flown by Bobby Oxspring, I have wanted a Mk1 to do this a long time and held off to await a decent kit, but I got impatient and with my much reduce stash went for the Revell plus aftermarket instead. I should not have bothered.
I will carry on with this crappy Revell though and see what else Revell cocked up in it.
The box
See for yourself.
