Revell 1/32 Me109 G-6
Barry I think your being a tad harsh on Revell I think you've been spoilt on the more expensive models you've built. Here's a link to the the exact same model I built in 2014, I was very happy with the results I had, https://www.scale-models.co.uk/threa...bf109g6.20694/.click on the photos to see the images not the links in blue above. Good luck with your build it seems to be coming along just fine.Comment
Barry I think your being a tad harsh on Revell I think you've been spoilt on the more expensive models you've built. Here's a link to the the exact same model I built in 2014, I was very happy with the results I had, https://www.scale-models.co.uk/threa...bf109g6.20694/.click on the photos to see the images not the links in blue above. Good luck with your build it seems to coming along just fine.Comment
I have been laying down some detail on the internals. I have to matt varnish and do final washes,‘pigments and some aluminium detailing before assembling the cockpit.
Some punted subs so far.
[ATTACH]400017[/ATTACH]
[ATTACH]400018[/ATTACH]
The I.p. Is waiting for the ddd Ed dal solution to dry.Comment
Cockpit came together nicely.
[ATTACH]400112[/ATTACH]
[ATTACH]400113[/ATTACH]
I have been quite hard on Revell but, credit where credit is due, the fit of the fuselage halves could not be bettered by Tamiya.
[ATTACH]400114[/ATTACH]
Not a lot of sanding/filling needed partly due to the upper and lower panel lines but also because of the engineering and fit.
[ATTACH]400115[/ATTACH]Comment
This is an easy one to mask. Underside first.
The topside - I am using the late canopy to mask the cockpit, a bit of blue roll in the pit to catch some overspray that might get through.
I then sprayed black primer. There are just a few areas where I need to treat the seams, I used some Mr Dissolved Putty, which shows up white in the pics.
I will sand when fully cured and re-prime before spraying the first base coat.Comment
A bit of filling and sanding done then the lower camo. I do like Luftwaffe schemes, there is always a lot of interest and variation in them. It is one explanation of why German WW2 subjects are so popular.
RLM076 done, the underside wingtips will be white as will the rudder. Under the nose it will be RLM04 yellow.
