Revell AV8B Harrier in 1/144 scale
  • Steve Brodie
    • Sep 2014
    • 4652
    #16
    Nice, good work on the blow doors, pretty sure an American company make a resin replacement set, not that you need it
    • yak face
      • Jun 2009
      • 13870
      • Tony
      #17
      Bit more progress on the Harrier today . Got the canopy on and the two TINY air scoops that sit either side of it. How i managed to attach these without losing them is a miracle. The rest of the parts to be added will be done after paint as it would be impossible to try and mask the two different colours ( its going to be very tricky even now) Click image for larger version
ID:	1134608Click image for larger version
ID:	1134609Click image for larger version
      • Mini Me
        • Jun 2018
        • 10711
        #18
        Nice work Tony.....you pass muster as a small scale modeler.....and the carpet monster is starving while you have successfully managed those tiny bits of styrene. Well done Sir. :thumb2:
        Rick H.
          • 22788
          #19
          Looking very good.
          • Neil Merryweather
            • Dec 2018
            • 5206
            • London
            #20
            Scary -in a good way, of course
              No PE? :smiling2::tongue-out3:
              • yak face
                • Jun 2009
                • 13870
                • Tony
                #22
                Today i started preparing all the tiny parts to be added after painting. The very fragile nicely detailed undercarriage was extremely carefully detached from the sprue and attached to a stirring stick . The front pair of exhausts were solid on the end so i drilled these out and cleaned them up then fixed these and the rear pair to the stick . All the little bits and the main airframe were then primed in Halfords white .Click image for larger version
ID:	1134732Click image for larger version
ID:	1134733Click image for larger version
ID:	1134734Click image for larger version
ID:	1134735Click image for larger version
ID:	1134736Click image for larger version
                • adt70hk
                  • Sep 2019
                  • 10438
                  #23
                  And people think 1/72 is small....
                  Great work so far Tony!!
                    • 22788
                    #24
                    Coming along nicely Tony
                    • yak face
                      • Jun 2009
                      • 13870
                      • Tony
                      #25
                      Cheers everyone , I cant recommend this kit highly enough , the detail would put many a 1/48 kit to shame , just make sure youve got a good magnifier and some fine tweezers!!!
                      • yak face
                        • Jun 2009
                        • 13870
                        • Tony
                        #26
                        Time for paint on this one now . I started with the underside grey ( in this case fs36320 dark ghost grey) then when cured i masked up the underside and applied the top colour ( fs 36231 dark gull grey) . The masking was very tricky as not only is it so small but the three pylons on each wing made it more difficult . Anyways its done and ive taken off the masking and it worked very well . The distinction between the two greys is almost imperceptible at a distance but it is on the real thing as well. Ive just got the nose cone to do now then its on to the undercarriage and missiles. Click image for larger version
ID:	1134892Click image for larger version
ID:	1134893Click image for larger version
ID:	1134894Click image for larger version
ID:	1134895Click image for larger version
                          • 22788
                          #27
                          Great work Tony. Being such a small kit, it could be very easy to flood the paint, but you’ve done a great job of it.
                          • yak face
                            • Jun 2009
                            • 13870
                            • Tony
                            #28
                            Got the decals on , some of which were really tiny! The control surfaces were highlighted then I gave it a coat of satin varnish as i wanted to get the slightly shiny finish seen on most modern aircraft, but it looked too shiny so I gave it a quick misting of matt to dull it down a bit . Next up is unmask the canopy and get the undercarriage and sidewinders fitted .Click image for larger version
ID:	1135376Click image for larger version
ID:	1135377Click image for larger version
                            • yak face
                              • Jun 2009
                              • 13870
                              • Tony
                              #29
                              Undercarriage now done and the Missile rails and sidewinders have been fitted . The sidewinders were quite a bugger to paint and decal , the red and yellow decal stripes not wanting to play ball and taking a lot of persuading to wrap around the tiny diameter of the missile . Click image for larger version
ID:	1136092Click image for larger version
ID:	1136093Click image for larger version
                              • Fernando N
                                • 2448
                                #30
                                Lovely little Harrier Tony :thumb2:
