The paint i mentioned earlier is the ‘ have glass ‘ grey in the Hataka US Greys set ive got , I’ll get it out and have a look at it and let you know what its like chris , cheers tony
Italeri 1/72 F-35 B Lightning II
Heres the Hataka ‘ have glass ‘ grey chris . I painted it on a piece of white paper to try and give you an idea of what it looks like . Its basically a dark grey with a metallic sheen , in otherwords a dark gunmetal . If you didnt want to go down the route of buying the hataka paint then i reckon a mix of vallejo Model color basalt grey and model air Gunmetal in a ratio of maybe 90 / 10 should give something like . Obviously you’ll have to experiment with the ratios but if youve got the colours then it should be fairly straightforward , hope this helps , cheers tonyComment
Interesting....thanks Tony.
Repainting is out of the question, but perhaps a little gun metal in the varnish might work?
I’ll think on it.Comment
Have spent some time mucking about with a few varnishing tests.
In each image there are four patches of three coats of the following (top left clockwise):
1. 2/1 gloss varnish / gun metal
2. 3/1 gloss varnish / VMC real steel
3. 2/1/1 gloss varnish / VMC real steel / VMA black
4. 2/1 gloss varnish / VMC real steel
Bottom row has had a matt varnish, which will be satin on the real thing judging from real examples.
Combination 1. gives a good effect, neutralising the colours at an angle, but it's too bright. I'm trying to dull them down a bit and this is doing the opposite.
On the other hand, combo 3 is too dark and adding any pigment creates streaking which I definitely need to avoid.
Overall I think combo 2 is the best.Comment
Update No. 13 - Painting cont'd
I said I might not, but I couldn't ignore it. So I spent another collection of hours masking the underside and painting it.
Just prior to painting I found a clog in my airbrush in the collar that sits between the trigger and the paint cup that was grabbing the needle and keeping it open, so while I was cleaning this with nail polish remover, disaster struck. I toppled the bottle in a clumsy swipe of the arm and splashed the corrosive solution all over the place.
Thankfully the model was not completely doused. I started to try to dab it off but realised quickly that the best thing to do was to leave it to evaporate.
Some repairs to the top will be necessary.
I'll definitely be able to fix it, but through my own inability to control my limbs I have added a 5th round of paint application to something I hoped would be 2 rounds!
Feels like it will never end at the minute!Comment
Chris,
Glad to know that the accident with the nail varnish remover didn't right off all your hardwork.Comment
