Andrew's 1/72 Monogram Bf110E-1
  • Lee Drennen
    • 7711
    #16
    Andy. Great looking updates and resources thanks I’ll need that when I start building mine
    • adt70hk
      • Sep 2019
      • 10409
      #17
      Lee
      Thanks very much be and glad I could be of assistance!!
      ATB
      • adt70hk
        • Sep 2019
        • 10409
        #18
        Hi all
        Apologies for not being around much. Very little time for the forum this week.
        I managed to get the bombs, props and splinter camo done at the weekend.
        Although it's not obvious the yellow coat on the bombs isn't perfect as from what I've seen it was seems to have been roughly applied sometimes.
        The splinter camo is done but I was aiming for a soft edge rather than a hard one as per Steve's (aka Stona) suggestion (pic below). The plan didn't work as I was hoping so I might have a go at doing the soft edge free-hand. The green is looking a bit thin because I was trying to aim for a warn/weathered look but it looks a bit too thin in places. You'll also notice my paint pattern is the reverse of the one below, as you can see dark paint on the engine cowlings (again something Steve picked up).
        I still have to do the blotches on the side.
        ACW as usual
        ATB
        PS sorry for the slightly blurry pic and lighting. They were taken in a rush.
        • Steven000
          • Aug 2018
          • 2827
          • Steven
          • Belgium
          #19
          Looks great! :thumb2:
          • Mini Me
            • Jun 2018
            • 10711
            #20
            Beautiful camo. Rick H.
            • adt70hk
              • Sep 2019
              • 10409
              #21
              Gentleman, thank you very much for the support. Hopefully, I won't make a complete hash of the soft edges........ :cold-sweat:
              • Lee Drennen
                • 7711
                #22
                Andrew. Your doing great like Rick said the camo is great
                • adt70hk
                  • Sep 2019
                  • 10409
                  #23
                  Thanks Lee, much appreciated!
                  ATB
                    • 18903
                    Nice rendition of the splinter cam. Don’t worry too much about the soft edges, this is 1/72 so it wouldn’t be very noticeable anyway.
                    • adt70hk
                      • Sep 2019
                      • 10409
                      #25
                      Thanks Tim!
                      • adt70hk
                        • Sep 2019
                        • 10409
                        #26
                        Hi all
                        So I got a bit more done at the weekend.
                        Against my better judgement (and everyone else's) I had a go at soft edges. I really struggled to get it as tight as I liked and also covered a bit more of the RLM02 than intended. Also struggled with the blotches too.....I just really struggled to get the pressure/mix combo right for some reason.....but at least that's something else new I've had a go at.
                        The exhausts were done using my own patented 'metal and rust technique' as described here. I also made some home made masks for the underwing plane ID letters - first time I've tried it. One came out better than the other but at least they're on the underside and so won't be seen too much.
                        I also mounted the bombs and managed to get the gloss varnish and the decals on too.
                        The decals are pretty thick, the printing was not the finest and they had a lot of extra carrier film that needed trimming but went down okay(ish) - my main worry was that at 50+ years old they would disintegrate but they held up fine. Being so thick they do stand a little bit proud but as this is a basically a practice piece I'm not that worried.
                        ACW as usual
                        ATB
                        Apologies for the slightly blurry pic below too....the camera focussed on the mug in the background for some reason.....
                        [ATTACH]404917[/ATTACH]
                        [ATTACH]404918[/ATTACH]
                        [ATTACH]404919[/ATTACH]
                        [ATTACH]404920[/ATTACH]
                        [ATTACH]404921[/ATTACH]
                        [ATTACH]404922[/ATTACH]
                        • adt70hk
                          • Sep 2019
                          • 10409
                          #27
                          Hi all
                          So other than having to stick on the small sticky out bits and pieces that ask to get broken off during construction and painting, removing the canopy mask, gluing the base on and adding the aerial wires, this is done.
                          I finished off with an attempt (not that successful) to do some exhaust muck on the wings and then an overall wash of a mix of darkish grey and sepia vallejo washes. I added a bit too much sepia in hindsight making it browner than I wanted and is also a bit heavy on the underside (but not as dark as it looks) but that's all part of the learning process.
                          The base has come out a lot more mottled and blue than it appears in the pics and gives quite a good sky effect IMHO, much better than my base for my 109 & Spit Dogfight Doubles
                          ATB
                          • adt70hk
                            • Sep 2019
                            • 10409
                            #28
                            Hi all
                            So I was hoping to have this finished yesterday but the stand proved problematic and would not hold the plane on properly. So I had to rip it out and add a bit of reinforcement late last night, which seems to have worked. As you'll see the reinforcement needs some tidying up.... :sad:
                            In putting the stand together I bent it slightly after putting it in boiling water and it also has a slight nose down attitude, meaning it looks like it's in a gentle downwards left hand turn - which hopefully looks a bit more dynamic than the level flight the stand would have it in. It also means you get a better view of the plane.
                            The canopy mask came out really well considering it was my first time doing it on so many panes. It does need a slight touch up in one place where I goofed on removing it...:crying:
                            Next up are the aerial wires and we're all done!
                            ACW as usual.
                            ATB
                            [ATTACH]405487[/ATTACH]
                            [ATTACH]405488[/ATTACH]
                            [ATTACH]405489[/ATTACH]
                            [ATTACH]405490[/ATTACH]
                            • Steven000
                              • Aug 2018
                              • 2827
                              • Steven
                              • Belgium
                              #29
                              Very nice model Andrew! :thumb2:
                              Steven
                              • adt70hk
                                • Sep 2019
                                • 10409
                                #30
                                Steven
                                Thanks Steven. I'm pretty happy with it in the whole. You've got to start somewhere with something new.
                                ATB
