Eduard 1/48 Fokker D.VII
    After the Albatros D.III & the Fokker Dr.I, I'm going for the ultimate WWI fighter - the Fokker D.VII
    I have a Roden boxing in my stash, but I have two Eduard versions:
ID:	1135664Click image for larger version
    I want to use both as German WWI aircraft, and with a bit of cross kitting, I can turn the MAG Red Star version into a 1918 fighter ( it has a different engine, different fuselage, different machine guns ). There are enough spare parts - especially the fuselage in the OAW version to do this - the only part that has to come from elsewhere is an exhaust - and that is an alternative from the Roden Model!
    These are the weekend versions, no PE, masks etc. The D.VII has minimal rigging - just as well with the extensive decalling.
    These D.VIIs had the lozenge covering on upper & lower wings ( and sometimes fuselage as well ). I probably won't be using the Eduard decals, as I have an after market decal sheet ( Print Scale ), which provides me with the additional lozenge sheets & some fancy artwork versions.............
    I'll put up some sprue shots shortly
    A box full of bits:
    Fuselages - one spare, which will be used................
    The rest of the spruesClick image for larger version
ID:	1135672Click image for larger version
ID:	1135673Click image for larger version
    And decals - not Printscale, but Lifelike.
    And lozenges, top, bottom & ribtapes - I may just have enough!
    One of the problem will be deciding exactly when to apply the decals. I can see that the decal solutions will be taking a hit!
    • Ralph
      • Oct 2020
      • 158
      You must be seeing double with all these wings recently :smiling3:.
        • 18932
        Another interesting subject to build. I have the Red star job in the stash so it will be good to see how this goes together....
          Tim,
          I have the Red Star version, because it was the cheapest Eduard Fokker D.VII - and still is! I didn't realise at the time you couldn't make a WWI version 'out of the box'. The surplus bits from the other Eduard Fokker has solved that!
          • Neil Merryweather
            • Dec 2018
            • 5199
            • London
            this looks like fun, Dave- I'm in
            • adt70hk
              • Sep 2019
              • 10428
              Good luck Dave!
                • 18932
                I think I bought that kit cheap at a show for the same reason.....but until you posted this, I didn’t know it wouldn’t produce a WW1 version either.....
                  Tim,
                  the fuselages are different - the WWI is grey, the Red Star caramel ( just taped together to show differences )
                  This is to take a different engine, but the original engine is still included - which I've put together & detail painted. The Red Star version also has Vickers mg, but the original Spandau guns are on the sprue.
                  The differences only become apparent when you lay the sprues out next to each other............
                    A miserable rainy dull day here, so I cracked on:
                    The fuselage is just about ready to be closed. Some spare decals used for instruments & masking tape for seatbelts
ID:	1135814Click image for larger version
                    Apart from really tiny parts - the seat frame being the worst all parts fitting well, but the instructions do need careful study
                      Fuselage closed - no need for clamps, just tape to hold it. No nasty noises!
                      • adt70hk
                        • Sep 2019
                        • 10428
                        Looking very good Dave. Keep up the good work.
                        ATB
                          • 18932
                          Looks good Dave. Thanks for the comparison info as well.
                          • The Smythe Meister
                            • Jan 2019
                            • 6248
                            Nice one Dave,looks great :thumb2: ,
                            Thanks for the info too,most interesting,
                            Andy
                              The Fokker has very little painting, the nose is dark green & the tail surfaces are white ( with green decal stripes ). The rest of the airframe is essentially covered in decals. I just brush applied a gloss varnish coat, then made a start, by applying most of the pale undersides
                              I used Humbrol Decalfix - it's a bit fierce, but there is such a large area to cover, I reckon it's needed.
                              I'll let this dry overnight & then do the darker upper surfaces tomorrow.
                              Once these are applied, I'll seal all in with varnish, then comes the really tedious part - applying the rib tapes - each an individual decal.................
