1/9th Scale B-17G
  • StevenRB
    • Oct 2020
    • 320
    1/9th Scale B-17G
    I cut out the patterns to transfer them onto three layer 3/32" balsa sheeting.
  • StevenRB
    • Oct 2020
    • 320
Name:	B-17G Bulkheads..jpg
    Now the patterns are ready to be cut out of the balsa sheeting.
    • StevenRB
      • Oct 2020
      • 320
      One of the bulkheads where the stabilizer goes.
      • StevenRB
        • Oct 2020
        • 320
        Cut out all 52 left side right side bulkheads.
        • StevenRB
          • Oct 2020
          • 320
          One side of the fuselage.
          • StevenRB
            • Oct 2020
            • 320
            Closeup of the tail section. I've been using a strip planking method similar to old boat making.
            • StevenRB
              • Oct 2020
              • 320
              The wing saddle area. This will be partly cut out later and fitted to the underside of the fuselage.
              • StevenRB
                • Oct 2020
                • 320
                I made dozens of these planks from a balsa stripper tool. These are best to go on round surfaces such as the fuselage and engine nacelles. Wings and tail surfaces get sheeting.
                • StevenRB
                  • Oct 2020
                  • 320
                  This is the balsa stripper. Using the thumbscrew and turning it will give you the width you require to cut.
                  • StevenRB
                    • Oct 2020
                    • 320
                    Here are two pieces st together. They have angle cuts on them to help reduce gaps in the joints.
                    • StevenRB
                      • Oct 2020
                      • 320
                      The wing is a 3 piece unit. This is the central part with the four engines and main landing.
                      • StevenRB
                        • Oct 2020
                        • 320
                        One of the four Saito .91 four stroke engines. This will pull a 3 blade 15"x3" diameter and pitch prop in order.
                          • 18930
                          Wow, that is some beast.....I saw a similar sized Lancaster engines being run up (not flown) at the model engineering exhibition in Earl’s Court years ago. They had blokes hanging on to the wings to stop it taking off......quite impressive really.
                            • 15735
                            Hi Steven
                            That is some model. Are you working from a set of plans? Very impressive.
                            • adt70hk
                              • Sep 2019
                              • 10422
                              Oh my word!
