The rivets certainly are not subtle but once I get three coats of varnish and washes on they will be OK.
As for the difference in sheen, there is certainly one but the lighting does exaggerate it. As for why...
MRP is a very thin paint with exceptionally fine pigment, in fact it is more ink-like than paint. It is so thin that it is really affected by the surface underneath, even to the extent of sometimes revealing the 'sworls' of plastic from when it was injected into the mold. This quality is one of the good things actually, as it shows how even many coats of paint and varnish do not hide detail. It does mean that the shinier and smoother the surface is where it is sprayed the shinier and smoother the top coat is... The primer is not as smooth and shiny as the Dark Earth that was sprayed onto it, so the Dark Green sprayed onto the Dark Earth looks a bit shinier still.... None of this is an issue as I will be spraying a sealing coat of gloss varnish before washes, then two coats of matt varnish and it will all end uplooking fine with no sheen difference at all. In fact just one good matt or semi-matt varnish coat makes all the difference.
