Magnifier!? CHEAT! :tongue-out3::tongue-out2::tongue-out3::tears-of-joy:
Tamiya 1/48 Avro Lancaster B Mkiii
I’m after some advice from those who may have already built this model
Themselves. Beside the pilot seat in the cockpit there is a pull down seat in the instructions. However, I have used some the etched parts and one such part which I can’t identify sits over where the seat would go. Now either the etched box section is the seat or else it’s a slightly different setup. Or do you have to mod the Tamiya stock seat to for back in this space some how. I have shown the Tamiya instructions below plus some pictures of my setup with black etched parts in place and one showing roughly where the stock seat would have been fitted.
thanks in advance, CarlComment
Carl,
Never built the Lanc at this scale - but looking at the instructions the part #B17 is the seat, this folds up and the "leg" #B10 supports it in the open or up position. There is a smaller cushion or seat back as can be seen in this picture fastened to the fuselage to the left side of the engineers panel;-
No doubt someone will be along shortly with the correct answer for you!! :smiling:
HTH
Paul.
:smiling:Comment
Carl,
[ATTACH=CONFIG]n1138319[/ATTACH]
HTH
Paul.
:smiling:
Cushion on the Tamiya model.
I may need to do some scratch work (not something i have done much of).
CarlComment
Hi Carl. Are you sure that etched part isn’t the missing cushion? The Tamiya part would then go in underneath....Comment
Carl - last link - courtesey of Aircar
Lancaster Builds
This one shows 1/48th interior;-
2010 Build
Paul.
:smiling:Comment
Lancaster Builds
2010 Build
Paul.
:smiling:Comment
If you haven't already had too many links, try this one: https://www.pan3sixty.co.uk/portfoli...89-at-duxford/Comment
I’ve completed the cockpit, and now stuck the two fuselage halves together so no going back now. So far fit seems quite good. There are a few minor raises edges where the two parts join, probably could of lined up better had I noticed at the glueing stage. Sure a bit of sand paper or small amount of filler can sort any minor variations.Comment
