Nice job Carl. That primer has gone on smooth and tight hasn’t it....
It’s a very fine & thin primer and you need to spray it at very low psi, like 10psi straight from the bottle or else you run out of paint after one wing-lol. Barry in this forum swears by this stuff so felt I needed to give it a go. Only negative is it is quite strong smelling compared to normal acrylic paints.
Sounds worth a look to me. Does it sand well after drying? I could never get on with stynilres type acrylic primers because I found they did sand well, making post-priming remedial work very hard to sort out.
It sands perfectly. None better simply because it is so thin. No feathering or adhesion issues.
I managed to do the main painting over Christmas so she’s looking more like the Lancaster should look now.
First experience using MRP paints is that they go on lovely and leave an almost perfect finish. I also used some camo mask this time which Ive never tried before and they also worked a treat.
I have been experimenting with some subtle paint techniques under the main colours which I’m not sure went exactly as planned but they don’t appear to have in any way distracted from the overall finish. You might just be able to make out some slight shading on the wings under the camo? All in all I’m very pleased with how the paint turned out as clearly this is the make or break of any model build so I feel a bit more relaxed now it’s done.
Still plenty to do yet to complete such as wheels fitting, Bomb bay and bombs plays decors and possibly some weathering if I feel brave enough at the end.[ATTACH]408874[/ATTACH]
[ATTACH]408872[/ATTACH][ATTACH]408873[/ATTACH]
Ps: a little thanks to Barry for his help and advice during this build so far.
I’m undecided, I bought these additional Warbirds decors for the Lancaster and can’t decide which I prefer . There’s Victorious Virgin or Fanlight Fanny.
I think I know which one I prefer but let’s hear what others think please?
[ATTACH]409182[/ATTACH]
