Yaks ‘century series’ in 1/48 part 4 - the Lockheed F-104C Starfighter
The starfighter has now had a couple of coats of Klear to seal the decals in and give a nice uniform sheen . The tail area was matt varnished and masked off prior to this , so that the heat staining effects can be applied easier ( eye shadow ) . Ive also been sorting the sidewinders . The kit supplied Aim 9Bs were not a bad representation but no stencils or stripe decals were provided . So out with the spare decal box and they got jazzed up with stencils and stripes , the seeker head made by sanding off the end and adding a blob of kristal kleer to represent the glass . Next up heat staining and then all the sticky out bits .
Made a start on the undercarriage yesterday . The u/c legs and bays / doors are really nicely detailed , the mainwheels and tyres especially - equal to any resin replacement . Astonishing when you think the kit was first tooled in 1978. I had to fit a couple of thin strips of styrene strip to the front part of the main bay so the front doors would fit flush . These doors hang open slightly when the undercarriage is extended so I had to get a good fixing via the strips . I also had a look at the pitot tube , the kit version had two mould seams and a couple of sprue attachment points to get rid of , so I decided on a homemade brass replacement using tube and rod . This has a funky red and white stripe scheme ,but unlike the delta dagger ( spiral ) this ones a straightforward hoop type. Next up heat staining on the rear fuselage .
