Trumpeter 1/32 SU-25 A Frogfoot
  • BarryW
    • Jul 2011
    • 6010
    #46
    Originally posted by Archetype
    As good as it looks, it's not many steps away from a pre-painted assembly only kit. I do hope it isn't adopted across the board as I much prefer the work and effort of painting and detailing. It's all part of the fun of the hobby.
    It’s a choice, an alternative to etch sets that is better than etch. That is it. You can still do it the old fashioned way if you prefer. I sometimes use detailing sets, sometimes not - its good to have options.
      Absolutely. The appeal of these is obvious and particularly if you can't get on with etch (which is most people I think!).
      I think you got my point though, it's mportant to have choices and I hope that remains.
      • scottie3158
        • 14201
        • Holbeach
        #48
        Barry,
        Those up grades are excellent are they vac formed to get the detail?
        • BarryW
          • Jul 2011
          • 6010
          #49
          Barry,
          No,
          3D printed vinyl on decal paper
          • JR
            • May 2015
            • 18273
            #50
            Barry. Although not a wingy by any means this has been a great build to follow.
            The only thing that's is of major concern is the cleanliness and neatness of your bench, this comes as the President of the Untidy Bench club :nerd:
            • boatman
              • Nov 2018
              • 14474
              • christopher
              • NORFOLK UK
              #51
              The only thing that's is of major concern is the cleanliness and neatness of your bench, this comes as as the President of the Untidy Bench club :nerd:
              YEA you are John an its about time its resarectied
              • Defiant911
                • Feb 2020
                • 640
                #52
                Originally posted by BarryW
                I spent an hour with the Quintas detailing set....
                These are described as 3D decals and are an alternative to etch detailing sets.
                Well I have used etch sets several times and I have a love/hate relationship with them while my relationship with decals is pure hatred, so how do these match up....
                just feel the love people.......
                Materials used:
                cocktail sticks
                white glue
                thick c.a.
                warm water
                fine pointed tweezers
                cotton buds
                Forget conventional decals, these are vinyl so they have strength and do not splinter and there is no carrier film. The printing and detail are superior to etch and, of course, they have 3d detailing and are not just flat.
                Starting with the main i.p. I applied a layer of white glue over the plastic panel then remove the detailing part from the backing paper in the usual way.
                [ATTACH=CONFIG]n1140297[/ATTACH]
                I blotted excess water from the ‘decal’.
                [ATTACH=CONFIG]n1140296[/ATTACH]
                then positioned it on the panel, a perfect fit.
                [ATTACH=CONFIG]n1140295[/ATTACH]
                There are a couple of other small items to add, then...
                [ATTACH=CONFIG]n1140294[/ATTACH]
                the panel is pictured next to a couple of levers that need adding. I will use thick c.a. for these, they have more ‘substance’ than the awful etch equivalent so I am optimistic that this will work. I will wait though a few hours to make sure the main panel is fully dry before I attach these.
                some small details to various parts, all dead easy.
                [ATTACH=CONFIG]n1140293[/ATTACH]
                [ATTACH=CONFIG]n1140292[/ATTACH]
                A side panel, next to a lever to add, again I will do it after the main panel is dry.
                [ATTACH=CONFIG]n1140291[/ATTACH]
                Now, some parts need ‘building out’ and to be given more depth. You can see below a small part to be layered onto the larger side panel.
                [ATTACH=CONFIG]n1140290[/ATTACH]
                Easy peasy.....
                [ATTACH=CONFIG]n1140289[/ATTACH]
                but there is more to be layered on top of that... a lever needs making up from three pieces...
                [ATTACH=CONFIG]n1140288[/ATTACH]
                I used a small drop of thick c.a.
                [ATTACH=CONFIG]n1140287[/ATTACH]
                that’s the two halves together just the end to go as shown clearly in the instructions.
                [ATTACH=CONFIG]n1140286[/ATTACH]
                All done...
                [ATTACH=CONFIG]n1140283[/ATTACH]
                Below a side consol fitted but with a number of levers etc needing to be added later with c.a.
                [ATTACH=CONFIG]n1140285[/ATTACH]
                below are parts for the seat.
                [ATTACH=CONFIG]n1140284[/ATTACH]
                when I get back to the bench I will finish the seat and i will see how well various levers attach....
                so far, very good indeed and very easy...
                I like those cockpit guages. Might have to try some of those myself.
                • minitnkr
                  Charter Rabble member
                  • 7538
                  • Dayton, OH USA
                  #53
                  An outstanding result. PaulE
                  • outrunner
                    • Apr 2019
                    • 2420
                    #54
                    Blimey my cracked thumb nail and skin!!!!
                    Anyway, back to business.....
                    I can confidently say that these 3D printed detailing decals are the way forward. Forget etch, it really does not match up to this product in any way. It’s better detailed, better fitting, easier to use and simply looks the biz.....
                    I believe that other companies are going to get in on these such as Kits World and if their stuff is as well produced as these Quintas sets then we will be in for a real treat.
                    The only drawback - right now a limited range of product but that will change. If you want a detailing set then look for 3D decals first and only use etch if you cannot find these.
                    There is a company in the UK doing that kind of thing and they stock a few makes, I ordered a dash set for a truck I have in the stash to see what they are like as it was cheap enough. The company is called Neomega-resin.com from Hinkley.
                    • BarryW
                      • Jul 2011
                      • 6010
                      #55
                      I have left out some detail from the nose and, instead, used plastic card to build a box into which I first applied some white glue and then poured in liquid gravity. Over the liquid gravity I poured some thin c.a.
                      [ATTACH]408972[/ATTACH]
                      [ATTACH]408971[/ATTACH]
                      The I matched up the fuselage sides. They are not a good fit.
                      The front matched up perfectly.
                      [ATTACH]408973[/ATTACH]
                      But look at the rear of the cockpit.
                      [ATTACH]408976[/ATTACH]
                      I am hoping that the mismatch will be obscured by the canopy being open.
                      The rear fuselage halves match up as well so this can only be poor engineering.
                      [ATTACH]408974[/ATTACH]
                      In trying to fit the fuselage halves I broke off the front gear leg. It should be easy to rectify though. I should never have fitted it so early on.
                      [ATTACH]408975[/ATTACH]
                        • 15693
                        Hi Barry
                        Stunning looking cockpit.
                        • Andy the Sheep
                          • Apr 2019
                          • 1864
                          • Andrea
                          • North Eastern Italy
                          #57
                          [ATTACH=CONFIG]n1140415[/ATTACH]
                          [ATTACH=CONFIG]n1140414[/ATTACH]
                          Barry, it looks like russian jet pilots like to have a caviar reservoir just in case they find themselves downed behind enemy lines....:smiling:
                          Sorry. Hat, gloves and coat, please...:rolling:
                          Inspiring work as usual.
                          Andrea.
                          • BarryW
                            • Jul 2011
                            • 6010
                            #58
                            This has been slow going largely because of the poor fitting larger parts. I have spent a lot of time filling and sanding but I have been getting on as well with a few minor parts as in the picture below.
                            This is strange, the model is made so quite a few panels are open that I want closed yet the cockpit, that I want open, has been designed to be closed! I need to research how the canopy looks when open but, as yet, i cannot see a good point to fix it to when open.
                            The fit the aftermarket probes on the front I need to drill the holes as the kit ones are undersize. This was a tricky bit of work and somewhat risky given how I needed to do this.
                            The gun cover fits so badly it needs a lot of filler and a lot of tape was used to hold it in the best position for cementing and minimising the filler needed.
                            Just looking at how the primer has sanded back demonstrates the amount of work needed. Remember that the primer was applied at a point when I thought the seams etc had been sorted. While at it I added a few of the less vulnerable aerials.
                            Looking at the fit and how vulnerable it is I decided not to have the cockpit ladder extended and that has given yet more sanding not reflected in the photo. If I close the pit up then that will be for the best anyway.
                            despite so much of my least favourite part of building a model, sanding,I am enjoying the challenges of the build. This though has to be the worse fitting Trumpeter kit I have ever built.
                            • outrunner
                              • Apr 2019
                              • 2420
                              #59
                              Oh dear, perhaps I might sell my 1/32 Trumpeter Sukhoi SU 27UB kit then.
                              Andy.
                              • BarryW
                                • Jul 2011
                                • 6010
                                #60
                                Andy.
                                No, don’t be out off. Not all Trumpy kits have these issues.
