Trumpeter 1/32 SU-25 A Frogfoot
  • BarryW
    • Jul 2011
    • 6010
    #76
    I did weathering with pigments and weathering pencils and after a final matt coat got on with final fittings.
    Still a fair bit to do.
    One decision I have made is not to use the Master metal probes at the front. I tried drilling the larger holes but I have not been able to get them to lay at the right angle. It is a really tricky operation that risks the integrity of the whole nose area given the angle at which you need to drill. I would strongly recommend against these. I will use the plastic ones instead although it will mean some repairs where I have drilled.
    • adt70hk
      • Sep 2019
      • 10409
      #77
      Looking good Barry.
      • BarryW
        • Jul 2011
        • 6010
        #78
        Originally posted by adt70hk
        Looking good Barry.
        It’s not bad but it’s far from my best. I have had to make too many compromises. It is an enjoyable build though. A day or two more and it will be done!
        • Defiant911
          • Feb 2020
          • 640
          #79
          Originally posted by BarryW
          I truly hate decals and with modern jets the painting on of markings with masks is just not practical and this is why I will infrequently do them.
          Trumpeters decals are the worse that you can get, they just have no strength and tend to splinter. I really should have bought an aftermarket set but, using Trumpeters, I should have known to have painted on decal film first to give them some strength. I didn’t sadly and, as usual, I started with the biggest decal first, the sharks mouth.
          True to form it splintered while on the backing paper (yes it was ‘loose’ and cracks appeared before I touched it).
          [ATTACH=CONFIG]n1141701[/ATTACH]
          Nevertheless I tried to piece it together on the model and it could have worked if the decal was not in many tiny pieces. Even then at first I thought I might be lucky and be able to use black paint to sort it.
          [ATTACH=CONFIG]n1141703[/ATTACH]
          ‘‘Twas not to be the case though. I could not rescue the decal it was in just far too many small pieces.
          So instead of applying decals I spent the session painting two coats of liquid decal film over them.
          As for the sharks mouth - another kit scheme also has a sharks mouth. A different style with no red. But it is use that or have none at all. Below is the other one that I will attempt to use.
          [ATTACH=CONFIG]n1141702[/ATTACH]
          Apart from the sharks mouth the other decals are not too big so hopefully with the decal film they won’t give me too much of a problem.
          It really is the large decals in 1/32 scale that you see on modern jets that are the big problem.
          You didn’t fancy spray painting the mouth in then, now try at would be impressive.
          • adt70hk
            • Sep 2019
            • 10409
            #80
            Don't be too hard on yourself. You've not seen the few planes I've built this year!
            • boatman
              • Nov 2018
              • 14474
              • christopher
              • NORFOLK UK
              #81
              AFTER THIS Barry what next ?
              • BarryW
                • Jul 2011
                • 6010
                #82
                A step into 1/24 scale. Currently awaiting delivery of some aftermarket for the Trumpeter Hawker Hurricane IID trop.
                A large scale Hurricane, desert scheme, an unusual appearance with the Volkes filter and two big tank busting cannon strapped under the wings, whats not to like!
                • Steve Brodie
                  • Sep 2014
                  • 4652
                  #83
                  Cant wait
                  • BarryW
                    • Jul 2011
                    • 6010
                    #84
                    I skived off into the garage for an hour this afternoon and finished it.
                    One pic here, I will upload more tomorrow sometime in a completed thread.
                    see this lot, all unused parts from this kit.
                    I need a bigger spares box....
                    • Steve Brodie
                      • Sep 2014
                      • 4652
                      #85
                      looks like a complete kit is left over !
